GXW4104 - problem splitting Outgoing calls to PSTN
Discussion in '3CX Phone System - General' started by alejtorres1, Aug 18, 2009.
  1. alejtorres1
    Jun 25, 2009
    Hello Everybody,
    I'm having a problem with a 3cx v 7.x (latest version) installation, on Windows Server 2003 R2, installed with 3cx cassini server, no AntiVirus, no Firewall, all LAN traffic, there are 2 network cards...
    Voip Equipment:
    2 Grandtream HT502 (each has 2 fxs ports... line/port 1 uses 5060 and line/port 2 uses 5062)
    1 Grandstream GXW4104 (with 2 pstn lines hooked up to ports 1 and 3),
    >> SIP destination port: ch1-4:5060;
    >> SIP listen port: ch1-4:5060++; (the ++ increments the port number by +2 for each line...)
    The incoming calls work great (forwards to the Digital Recep), but I´m having trouble with the outgoing calls:
    When the extension A (using the first Grandstream FXS HT502) makes a call, the 3cx outbound rule recognizes it's extension number and routes the call via the FXO Line 1 (by adding the prefix 991)
    The problem occurs when another user on the second HT502 dials, and the second OUtboud rule routes it to the other line (by appending the 993) .. the call order/command goes through to the GXW4104, it dials the PSTN number correctly, it rings on the destination phone, but when they answer there is no voice and the person who dialed the calls continues to hear ringing sound as if the call kept ringing on the destination phone....
    I set the log to verbose, it didn´t work, so I manually reset the services in the services MMC, and I think it's logging correctly (see below, correct me if Im wrong and my logs aren't detailed yet..)
    ( I had to manually terminated/hangup becuase if not it would "seem" to keep on ringing even though someone answered..)
    19:19:59.234 [CM503008]: Call(3): Call is terminated
    19:19:45.609 [CM505002]: Gateway:[HYRCO4104A] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Grandstream GXW4104 (HW 1.1, Ch:9) 1.0.1.25] Transport: [sip:192.168.6.12:5060]
    19:19:45.609 [CM503002]: Call(3): Alerting sip:10001@192.168.6.181:5062;user=phone
    19:19:43.562 [CM503004]: Call(3): Route 2: PSTNline:9943444804@(Ln.10000@HYRCO4104A)@[Dev:sip:10000@192.168.6.181:5060, Dev:sip:10002@192.168.6.181:5064;user=phone, Dev:sip:10003@192.168.6.181:5066;user=phone]
    19:19:43.562 [CM503024]: Call(3): Calling PSTNline:9933444804@(Ln.10001@HYRCO4104A)@[Dev:sip:10001@192.168.6.181:5062;user=phone]
    19:19:43.562 [MS210006] C:3.2:Offer provided. Connection(by pass mode): 192.168.6.50:5540(5541)
    19:19:43.562 [CM503004]: Call(3): Route 1: PSTNline:9933444804@(Ln.10001@HYRCO4104A)@[Dev:sip:10001@192.168.6.181:5062;user=phone, Dev:sip:10000@192.168.6.181:5060, Dev:sip:10002@192.168.6.181:5064;user=phone, Dev:sip:10003@192.168.6.181:5066;user=phone]
    19:19:43.546 [MS210000] C:3.1:Offer received. RTP connection: 192.168.6.50:5540(5541)
    19:19:43.546 [CM503010]: Making route(s) to "03444804"<sip:03444804@192.168.6.12>
    19:19:43.546 Remote SDP is set for legC:3.1
    19:19:43.546 [CM505001]: Ext.2400: Device info: Device Identified: [Man: Counterpath;Mod: X-Lite;Rev: General] Capabilities:[reinvite, no-replaces, unable-no-sdp, recvonly] UserAgent: [X-Lite release 1103d stamp 53117] Transport: [sip:192.168.6.12:5060]
    19:19:43.546 [CM503001]: Call(3): Incoming call from Ext.2400 to "03444804"<sip:03444804@192.168.6.12>
    19:19:43.546 [CM500002]: Info on incoming INVITE:
    INVITE sip:03444804@192.168.6.12 SIP/2.0
    Via: SIP/2.0/UDP 192.168.6.50:42820;branch=z9hG4bK-d8754z-ea372660eb08f933-1---d8754z-;rport=42820
    Max-Forwards: 70
    Contact: <sip:2400@192.168.6.50:42820>
    To: "03444804"<sip:03444804@192.168.6.12>
    From: "test ana"<sip:2400@192.168.6.12>;tag=6c3e6e0f
    Call-ID: ZjcyZDQ2N2QxYmM2MzZjYjcwZjM0NTJiZTVlZWJiYmQ.
    CSeq: 2 INVITE
    Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, NOTIFY, MESSAGE, SUBSCRIBE, INFO
    Proxy-Authorization: Digest username="2400",realm="3CXPhoneSystem",nonce="414d535c009a849f19:1eddd9995bedf3faa5783ae96172a638",uri="sip:03444804@192.168.6.12",response="8d0941fdf472c33134dd8f45f888499d",algorithm=MD5
    User-Agent: X-Lite release 1103d stamp 53117
    Content-Length: 0
    Anybody have any ideas ??
    thanks
    11,286
    360
    I haven't used either of those devices, but, looking at the log, i'm wondering why one call is trying 10000, 10001 and 10003, all involving the one outgoing phone number? Is there perhaps a failure when the call is first attempted on the original trunk?
