- Joined
- Jun 19, 2007
- Messages
- 21
- Reaction score
- 0
I am having some problems somewhere between 3cx and GXW4104. I have been having intermittent dropped calls...but a more serious problem is the Grandstream starts to flood my syslog server with messages(I have debug turned on), at about the same time 2 of the four lines I have configured on 3cx go into an unknown status...in bound calls just ring to the 2 lines in the unknown status...while the other 2 continue to work...but my main switch number is one of the unknown status lines and therefore the inbound hunt group doesn't roll over to the other 2 available lines.
Forgive my newbie-ness...but I could use some help...I have more data or logs, please ask...logs from both 3cx and GXW follow:
14:30:21.640 StratInOut:nHangUp [CM104007] Call(136): Call from Ln:10001@GXW-4104 to 800 has been terminated by Ln:10001@GXW-4104; cause: BYE; from IP:192.168.64.20
14:30:11.718 CallLegImpl:nConnected [CM103001] Call(136): Created audio channel for Ln:10001@GXW-4104 (192.168.64.20:5020) with Media Server (192.168.64.11:7388)
14:30:11.687 CallConf:nIncoming [CM103002] Call(136): Incoming call from unknown (Ln:10001@GXW-4104) to sip:192.168.64.11:5060
14:29:36.125 StratInOut:nHangUp [CM104007] Call(135): Call from Ln:10001@GXW-4104 to 800 has been terminated by Ln:10001@GXW-4104; cause: BYE; from IP:192.168.64.20
14:29:01.171 CallLegImpl:nConnected [CM103001] Call(135): Created audio channel for Ln:10001@GXW-4104 (192.168.64.20:5016) with Media Server (192.168.64.11:7386)
14:29:01.140 CallConf:nIncoming [CM103002] Call(135): Incoming call from unknown (Ln:10001@GXW-4104) to sip:192.168.64.11:5060
14:28:40.953 CallConf::Rejected [CM103005] Call(134) is rejected: Too many incoming calls
14:28:40.953 CallLegImpl:nIncoming [CM103000] Call(134): Number of simultaneous calls is limited by Administrator
14:28:28.890 CallConf::Rejected [CM103005] Call(133) is rejected: Too many incoming calls
14:28:28.890 CallLegImpl:nIncoming [CM103000] Call(133): Number of simultaneous calls is limited by Administrator
14:28:16.859 CallConf::Rejected [CM103005] Call(132) is rejected: Too many incoming calls
14:28:16.859 CallLegImpl:nIncoming [CM103000] Call(132): Number of simultaneous calls is limited by Administrator
14:12:20.203 CallConf::Rejected [CM103005] Call(131) is rejected: Too many incoming calls
14:12:20.203 CallLegImpl:nIncoming [CM103000] Call(131): Number of simultaneous calls is limited by Administrator
14:12:09.390 CallConf::Rejected [CM103005] Call(130) is rejected: Too many incoming calls
14:12:09.390 CallLegImpl:nIncoming [CM103000] Call(130): Number of simultaneous calls is limited by Administrator
14:11:57.343 CallConf::Rejected [CM103005] Call(129) is rejected: Too many incoming calls
14:11:57.343 CallLegImpl:nIncoming [CM103000] Call(129): Number of simultaneous calls is limited by Administrator
14:11:32.109 StratInOut:nHangUp [CM104007] Call(128): Call from Ln:10001@GXW-4104 to 800 has been terminated by Ln:10001@GXW-4104; cause: BYE; from IP:192.168.64.20
14:10:27.406 CallLegImpl:nConnected [CM103001] Call(128): Created audio channel for Ln:10001@GXW-4104 (192.168.64.20:5020) with Media Server (192.168.64.11:7384)
14:10:27.375 CallConf:nIncoming [CM103002] Call(128): Incoming call from unknown (Ln:10001@GXW-4104) to sip:192.168.64.11:5060
14:10:04.390 StratInOut:nHangUp [CM104007] Call(127): Call from Ln:10001@GXW-4104 to 800 has been terminated by Ln:10001@GXW-4104; cause: BYE; from IP:192.168.64.20
14:09:36.328 CallLegImpl:nConnected [CM103001] Call(127): Created audio channel for Ln:10001@GXW-4104 (192.168.64.20:5016) with Media Server (192.168.64.11:7382)
14:09:36.296 CallConf:nIncoming [CM103002] Call(127): Incoming call from unknown (Ln:10001@GXW-4104) to sip:192.168.64.11:5060
14:08:38.906 StratInOut:nHangUp [CM104007] Call(126): Call from Ln:10003@GXW-4104 to 800 has been terminated by Ln:10003@GXW-4104; cause: BYE; from IP:192.168.64.20
14:08:22.625 CallLegImpl:nConnected [CM103001] Call(126): Created audio channel for Ln:10003@GXW-4104 (192.168.64.20:5012) with Media Server (192.168.64.11:7380)
14:08:22.593 CallConf:nIncoming [CM103002] Call(126): Incoming call from unknown (Ln:10003@GXW-4104) to sip:192.168.64.11:5060
14:05:32.093 CallConf::Rejected [CM103005] Call(125) is rejected: Too many incoming calls
14:05:32.093 CallLegImpl:nIncoming [CM103000] Call(125): Number of simultaneous calls is limited by Administrator
14:05:16.296 CallConf::Rejected [CM103005] Call(124) is rejected: Too many incoming calls
14:05:16.296 CallLegImpl:nIncoming [CM103000] Call(124): Number of simultaneous calls is limited by Administrator
14:05:05.312 CallConf::Rejected [CM103005] Call(123) is rejected: Too many incoming calls
14:05:05.312 CallLegImpl:nIncoming [CM103000] Call(123): Number of simultaneous calls is limited by Administrator
14:04:53.265 CallConf::Rejected [CM103005] Call(122) is rejected: Too many incoming calls
14:04:53.265 CallLegImpl:nIncoming [CM103000] Call(122): Number of simultaneous calls is limited by Administrator
14:04:41.218 CallConf::Rejected [CM103005] Call(121) is rejected: Too many incoming calls
14:04:41.218 CallLegImpl:nIncoming [CM103000] Call(121): Number of simultaneous calls is limited by Administrator
14:04:29.203 CallConf::Rejected [CM103005] Call(120) is rejected: Too many incoming calls
14:04:29.203 CallLegImpl:nIncoming [CM103000] Call(120): Number of simultaneous calls is limited by Administrator
14:04:17.171 CallConf::Rejected [CM103005] Call(119) is rejected: Too many incoming calls
14:04:17.171 CallLegImpl:nIncoming [CM103000] Call(119): Number of simultaneous calls is limited by Administrator
14:04:05.093 CallConf::Rejected [CM103005] Call(118) is rejected: Too many incoming calls
14:04:05.093 CallLegImpl:nIncoming [CM103000] Call(118): Number of simultaneous calls is limited by Administrator
13:53:05.843 CallMgr::failResolveExtIp [CM200001] Failed to resolve external IP!
13:53:05.843 StunClient:rocess [CM215001] STUN failed to resolve external IP using server 80.239.235.209
13:53:02.781 StunClient:rocess [CM215001] STUN failed to resolve external IP using server 192.245.12.229
13:52:59.718 StunClient:rocess [CM115001] Send initial STUN request to 192.245.12.229
13:52:59.609 StunClient:rocess [CM215001] STUN failed to resolve external IP using server 80.239.235.209
13:52:56.546 StunClient:rocess [CM215001] STUN failed to resolve external IP using server 192.245.12.229
13:48:27.609 StratLink:nHangUp [CM104001] Call(117): Ext.110 hung up call; cause: BYE; from IP:192.168.64.232
13:47:24.062 MediaServerReporting:TMFhandler [MS211000] Call(117) Ext.110: DTMF (RTP) from 192.168.64.232:32568 arrived. in-band DTMF tone detection is turned off.
13:47:07.359 CallLegImpl:nConnected [CM103001] Call(117): Created audio channel for Ln:10003@GXW-4104 (192.168.64.20:5008) with Media Server (192.168.64.11:7378)
13:47:07.359 StratInOut:nConnected [CM104005] Call(117): Setup completed for call from Ext.110 to Ln:10003@GXW-4104
13:47:07.359 CallLegImpl:nConnected [CM103001] Call(117): Created audio channel for Ext.110 32568) with Media Server (192.168.64.11:7376)
13:47:07.343 CallConf:nProvisional [CM103003] Call(117): Ln:10003@GXW-4104 is ringing
13:47:04.484 CallConf:nIncoming [CM103002] Call(117): Incoming call from 110 (Ext.110) to sip:[email protected]
13:36:23.984 StratLink:nHangUp [CM104001] Call(116): Ext.110 hung up call; cause: BYE; from IP:192.168.64.232
13:34:35.343 MediaServerReporting:TMFhandler [MS211000] Call(116) Ext.110: DTMF (RTP) from 192.168.64.232:29284 arrived. in-band DTMF tone detection is turned off.
2007-08-24 14:30:12 User.Info 192.168.64.20 GS_LOG: [00:0B:82:0D:FC1][000][FF50][01000037] 683 sip.c Sess: 4 Send SIP message: 3 To 192.168.64.11:5060
2007-08-24 14:30:12 User.Info 192.168.64.20 GS_LOG: [00:0B:82:0D:FC1][000][FF50][01000037] 1463 sip.c Received SIP message: 0 Acc:0
2007-08-24 14:30:12 User.Info 192.168.64.20 GS_LOG: [00:0B:82:0D:FC1][000][FF50][01000037] 1463 sip.c Received SIP message: 200 Acc:1
2007-08-24 14:30:21 User.Info 192.168.64.20 GS_LOG: [00:0B:82:0D:FC1][000][FF50][01000037] cm_task.c 1577 Port:1 Sess:4 0 4 6 4
2007-08-24 14:30:21 User.Info 192.168.64.20 GS_LOG: [00:0B:82:0D:FC1][000][FF50][01000037] 598 cm_utility.c Port:1 Sess:4 gw_st: 4 cs_st: 0 from#: 1586
2007-08-24 14:30:21 User.Info 192.168.64.20 GS_LOG: [00:0B:82:0D:FC1][000][FF50][01000037] fxo_ctl.c 186 Port:1 DAA Hangup 2
2007-08-24 14:30:21 User.Info 192.168.64.20 GS_LOG: [00:0B:82:0D:FC1][000][FF50][01000037] 683 sip.c Sess: 4 Send SIP message: 4 To 192.168.64.11:5060
2007-08-24 14:30:22 User.Info 192.168.64.20 GS_LOG: [00:0B:82:0D:FC1][000][FF50][01000037] 1463 sip.c Received SIP message: 200 Acc:1
2007-08-24 14:30:23 User.Info 192.168.64.20 GS_LOG: [00:0B:82:0D:FC1][000][FF50][01000037] 683 sip.c Sess: 4 Send SIP message: 4 To 192.168.64.11:5060
2007-08-24 14:30:23 User.Info 192.168.64.20 GS_LOG: [00:0B:82:0D:FC1][000][FF50][01000037] 1463 sip.c Received SIP message: 400 Acc:1
2007-08-24 14:30:23 User.Info 192.168.64.20 GS_LOG: [00:0B:82:0D:FC1][000][FF50][01000037] 583 cm_utility.c Port:1 Sess:4 gw_st: 4 cs_st: 0
2007-08-24 14:30:26 User.Info 192.168.64.20 GS_LOG: [00:0B:82:0D:FC1][000][FF50][01000037] 1463 sip.c Received SIP message: 0 Acc:2
2007-08-24 14:30:42 User.Info 192.168.64.20 GS_LOG: [00:0B:82:0D:FC1][000][FF50][01000037] 1463 sip.c Received SIP message: 0 Acc:0
2007-08-24 14:30:56 User.Info 192.168.64.20 GS_LOG: [00:0B:82:0D:FC1][000][FF50][01000037] 1463 sip.c Received SIP message: 0 Acc:2
2007-08-24 14:31:13 User.Info 192.168.64.20 GS_LOG: [00:0B:82:0D:FC1][000][FF50][01000037] 1463 sip.c Received SIP message: 0 Acc:0
2007-08-24 14:31:27 User.Info 192.168.64.20 GS_LOG: [00:0B:82:0D:FC1][000][FF50][01000037] 1463 sip.c Received SIP message: 0 Acc:2
2007-08-24 14:31:43 User.Info 192.168.64.20 GS_LOG: [00:0B:82:0D:FC1][000][FF50][01000037] 1463 sip.c Received SIP message: 0 Acc:0
2007-08-24 14:31:57 User.Info 192.168.64.20 GS_LOG: [00:0B:82:0D:FC1][000][FF50][01000037] 1463 sip.c Received SIP message: 0 Acc:2
2007-08-24 14:32:13 User.Info 192.168.64.20 GS_LOG: [00:0B:82:0D:FC1][000][FF50][01000037] 1463 sip.c Received SIP message: 0 Acc:0
2007-08-24 14:32:27 User.Info 192.168.64.20 GS_LOG: [00:0B:82:0D:FC1][000][FF50][01000037] 1463 sip.c Received SIP message: 0 Acc:2
2007-08-24 14:32:44 User.Info 192.168.64.20 GS_LOG: [00:0B:82:0D:FC1][000][FF50][01000037] 1463 sip.c Received SIP message: 0 Acc:0
2007-08-24 14:32:58 User.Info 192.168.64.20 GS_LOG: [00:0B:82:0D:FC1][000][FF50][01000037] 1463 sip.c Received SIP message: 0 Acc:2
2007-08-24 14:33:14 User.Info 192.168.64.20 GS_LOG: [00:0B:82:0D:FC1][000][FF50][01000037] 1463 sip.c Received SIP message: 0 Acc:0
2007-08-24 14:33:28 User.Info 192.168.64.20 GS_LOG: [00:0B:82:0D:FC1][000][FF50][01000037] 1463 sip.c Received SIP message: 0 Acc:2
2007-08-24 14:33:44 User.Info 192.168.64.20 GS_LOG: [00:0B:82:0D:FC1][000][FF50][01000037] 1463 sip.c Received SIP message: 0 Acc:0
2007-08-24 14:33:58 User.Info 192.168.64.20 GS_LOG: [00:0B:82:0D:FC1][000][FF50][01000037] 1463 sip.c Received SIP message: 0 Acc:2
2007-08-24 14:34:15 User.Info 192.168.64.20 GS_LOG: [00:0B:82:0D:FC1][000][FF50][01000037] 1463 sip.c Received SIP message: 0 Acc:0
2007-08-24 14:34:28 User.Info 192.168.64.20 GS_LOG: [00:0B:82:0D:FC1][000][FF50][01000037] 1463 sip.c Received SIP message: 0 Acc:2
2007-08-24 14:34:45 User.Info 192.168.64.20 GS_LOG: [00:0B:82:0D:FC1][000][FF50][01000037] 1463 sip.c Received SIP message: 0 Acc:0
2007-08-24 14:34:58 User.Info 192.168.64.20 GS_LOG: [00:0B:82:0D:FC1][000][FF50][01000037] 1463 sip.c Received SIP message: 0 Acc:2
2007-08-24 14:35:15 User.Info 192.168.64.20 GS_LOG: [00:0B:82:0D:FC1][000][FF50][01000037] 1463 sip.c Received SIP message: 0 Acc:0
2007-08-24 14:35:29 User.Info 192.168.64.20 GS_LOG: [00:0B:82:0D:FC1][000][FF50][01000037] 1463 sip.c Received SIP message: 0 Acc:2
2007-08-24 14:35:45 User.Info 192.168.64.20 GS_LOG: [00:0B:82:0D:FC1][000][FF50][01000037] 1463 sip.c Received SIP message: 0 Acc:0
2007-08-24 14:35:59 User.Info 192.168.64.20 GS_LOG: [00:0B:82:0D:FC1][000][FF50][01000037] 1463 sip.c Received SIP message: 0 Acc:2
2007-08-24 14:36:15 User.Info 192.168.64.20 GS_LOG: [00:0B:82:0D:FC1][000][FF50][01000037] 1463 sip.c Received SIP message: 0 Acc:0
2007-08-24 14:36:29 User.Info 192.168.64.20 GS_LOG: [00:0B:82:0D:FC1][000][FF50][01000037] 1463 sip.c Received SIP message: 0 Acc:2
2007-08-24 14:36:46 User.Info 192.168.64.20 GS_LOG: [00:0B:82:0D:FC1][000][FF50][01000037] 1463 sip.c Received SIP message: 0 Acc:0
2007-08-24 14:37:00 User.Info 192.168.64.20 GS_LOG: [00:0B:82:0D:FC1][000][FF50][01000037] 1463 sip.c Received SIP message: 0 Acc:2
2007-08-24 14:37:16 User.Info 192.168.64.20 GS_LOG: [00:0B:82:0D:FC1][000][FF50][01000037] 1463 sip.c Received SIP message: 0 Acc:0
2007-08-24 14:37:30 User.Info 192.168.64.20 GS_LOG: [00:0B:82:0D:FC1][000][FF50][01000037] 1463 sip.c Received SIP message: 0 Acc:2
2007-08-24 14:37:46 User.Info 192.168.64.20 GS_LOG: [00:0B:82:0D:FC1][000][FF50][01000037] 1463 sip.c Received SIP message: 0 Acc:0
2007-08-24 14:38:00 User.Info 192.168.64.20 GS_LOG: [00:0B:82:0D:FC1][000][FF50][01000037] 1463 sip.c Received SIP message: 0 Acc:2
2007-08-24 14:38:16 User.Info 192.168.64.20 GS_LOG: [00:0B:82:0D:FC1][000][FF50][01000037] 1463 sip.c Received SIP message: 0 Acc:0
2007-08-24 14:38:30 User.Info 192.168.64.20 GS_LOG: [00:0B:82:0D:FC1][000][FF50][01000037] 1463 sip.c Received SIP message: 0 Acc:2
2007-08-24 14:38:47 User.Info 192.168.64.20 GS_LOG: [00:0B:82:0D:FC1][000][FF50][01000037] 1463 sip.c Received SIP message: 0 Acc:0
2007-08-24 14:39:00 User.Info 192.168.64.20 GS_LOG: [00:0B:82:0D:FC1][000][FF50][01000037] 1463 sip.c Received SIP message: 0 Acc:2
From Earlier in the day
2007-08-24 12:05:32 User.Info 192.168.64.20 GS_LOG: [00:0B:82:0D:FC1][000][FF50][01000037] fxo_ctl.c 166 Port:3 DAA Pickup 2
2007-08-24 12:05:32 User.Info 192.168.64.20 GS_LOG: [00:0B:82:0D:FC1][000][FF50][01000037] 683 sip.c Sess: 0 Send SIP message: 100 To 192.168.64.11:5060
2007-08-24 12:05:32 User.Info 192.168.64.20 GS_LOG: [00:0B:82:0D:FC1][000][FF50][01000037] 568 sip_handle_invite.c Sess: 4 INVITE From="unknown"<sip:[email protected]>;tag=27084e34 To="2091750"<sip:[email protected]:5060>
2007-08-24 12:05:32 User.Info 192.168.64.20 GS_LOG: [00:0B:82:0D:FC1][000][FF50][01000037] 620 sip_handle_invite.c Port:3 Sess:4;1 1 0;1 100;0
2007-08-24 12:05:34 User.Info 192.168.64.20 GS_LOG: [00:0B:82:0D:FC1][000][FF50][01000037] 683 sip.c Sess: 4 Send SIP message: 180 To 192.168.64.11:5060
2007-08-24 12:05:34 User.Info 192.168.64.20 GS_LOG: [00:0B:82:0D:FC1][000][FF50][01000037] sdp.c Acc:0 RTP payload type: 0
2007-08-24 12:05:34 User.Info 192.168.64.20 GS_LOG: [00:0B:82:0D:FC1][000][FF50][01000037] 683 sip.c Sess: 4 Send SIP message: 200 To 192.168.64.11:5060
2007-08-24 12:05:34 User.Info 192.168.64.20 GS_LOG: [00:0B:82:0D:FC1][000][FF50][01000037] 1463 sip.c Received SIP message: 3 Acc:0
2007-08-24 12:05:34 User.Info 192.168.64.20 GS_LOG: [00:0B:82:0D:FC1][000][FF50][01000037] cm_api.c 232 Start fax_detect on Port:3 sess: 4
2007-08-24 12:05:56 User.Info 192.168.64.20 GS_LOG: [00:0B:82:0D:FC1][000][FF50][01000037] 1463 sip.c Received SIP message: 0 Acc:2
2007-08-24 12:06:04 User.Info 192.168.64.20 GS_LOG: [00:0B:82:0D:FC1][000][FF50][01000037] 1463 sip.c Received SIP message: 0 Acc:0
2007-08-24 12:06:26 User.Info 192.168.64.20 GS_LOG: [00:0B:82:0D:FC1][000][FF50][01000037] 1463 sip.c Received SIP message: 0 Acc:2
2007-08-24 12:06:35 User.Info 192.168.64.20 GS_LOG: [00:0B:82:0D:FC1][000][FF50][01000037] 1463 sip.c Received SIP message: 0 Acc:0
2007-08-24 12:06:56 User.Info 192.168.64.20 GS_LOG: [00:0B:82:0D:FC1][000][FF50][01000037] 1463 sip.c Received SIP message: 0 Acc:2
2007-08-24 12:07:05 User.Info 192.168.64.20 GS_LOG: [00:0B:82:0D:FC1][000][FF50][01000037] 1463 sip.c Received SIP message: 0 Acc:0
2007-08-24 12:07:26 User.Info 192.168.64.20 GS_LOG: [00:0B:82:0D:FC1][000][FF50][01000037] 1463 sip.c Received SIP message: 0 Acc:2
2007-08-24 12:07:35 User.Info 192.168.64.20 GS_LOG: [00:0B:82:0D:FC1][000][FF50][01000037] 1463 sip.c Received SIP message: 0 Acc:0
2007-08-24 12:07:57 User.Info 192.168.64.20 GS_LOG: [00:0B:82:0D:FC1][000][FF50][01000037] 1463 sip.c Received SIP message: 0 Acc:2
2007-08-24 12:08:05 User.Info 192.168.64.20 GS_LOG: [00:0B:82:0D:FC1][000][FF50][01000037] 1463 sip.c Received SIP message: 0 Acc:0
2007-08-24 12:08:27 User.Info 192.168.64.20 GS_LOG: [00:0B:82:0D:FC1][000][FF50][01000037] 1463 sip.c Received SIP message: 0 Acc:2
2007-08-24 12:08:36 User.Info 192.168.64.20 GS_LOG: [00:0B:82:0D:FC1][000][FF50][01000037] 1463 sip.c Received SIP message: 0 Acc:0
2007-08-24 12:08:57 User.Info 192.168.64.20 GS_LOG: [00:0B:82:0D:FC1][000][FF50][01000037] 1463 sip.c Received SIP message: 0 Acc:2
2007-08-24 12:09:06 User.Info 192.168.64.20 GS_LOG: [00:0B:82:0D:FC1][000][FF50][01000037] 1463 sip.c Received SIP message: 0 Acc:0
2007-08-24 12:09:11 User.Info 192.168.64.20 GS_LOG: [00:0B:82:0D:FC1][000][FF50][01000037] cm_task.c 1577 Port:3 Sess:4 0 8 6 4
2007-08-24 12:09:11 User.Info 192.168.64.20 GS_LOG: [00:0B:82:0D:FC1][000][FF50][01000037] 598 cm_utility.c Port:3 Sess:4 gw_st: 4 cs_st: 0 from#: 1586
2007-08-24 12:09:11 User.Info 192.168.64.20 GS_LOG: [00:0B:82:0D:FC1][000][FF50][01000037] fxo_ctl.c 186 Port:3 DAA Hangup 2
2007-08-24 12:09:11 User.Info 192.168.64.20 GS_LOG: [00:0B:82:0D:FC1][000][FF50][01000037] 683 sip.c Sess: 4 Send SIP message: 4 To 192.168.64.11:5060
2007-08-24 12:09:11 User.Info 192.168.64.20 GS_LOG: [00:0B:82:0D:FC1][000][FF50][01000037] cm_task.c 1577 Port:2 Sess:3 0 4 6 4
2007-08-24 12:09:11 User.Info 192.168.64.20 GS_LOG: [00:0B:82:0D:FC1][000][FF50][01000037] 598 cm_utility.c Port:2 Sess:3 gw_st: 4 cs_st: 0 from#: 1586
2007-08-24 12:09:11 User.Info 192.168.64.20 GS_LOG: [00:0B:82:0D:FC1][000][FF50][01000037] fxo_ctl.c 186 Port:2 DAA Hangup 2
2007-08-24 12:09:11 User.Info 192.168.64.20 GS_LOG: [00:0B:82:0D:FC1][000][FF50][01000037] 683 sip.c Sess: 3 Send SIP message: 4 To 192.168.64.11:5060
2007-08-24 12:09:11 User.Info 192.168.64.20 GS_LOG: [00:0B:82:0D:FC1][000][FF50][01000037] 1463 sip.c Received SIP message: 200 Acc:0
2007-08-24 12:09:11 User.Info 192.168.64.20 GS_LOG: [00:0B:82:0D:FC1][000][FF50][01000037] 1463 sip.c Received SIP message: 4 Acc:2
2007-08-24 12:09:11 User.Info 192.168.64.20 GS_LOG: [00:0B:82:0D:FC1][000][FF50][01000037] 683 sip.c Sess: 3 Send SIP message: 200 To 192.168.64.11:5060
2007-08-24 12:09:11 User.Info 192.168.64.20 GS_LOG: [00:0B:82:0D:FC1][000][FF50][01000037] 1463 sip.c Received SIP message: 481 Acc:2
2007-08-24 12:09:11 User.Info 192.168.64.20 GS_LOG: [00:0B:82:0D:FC1][000][FF50][01000037] 455 fxo_ctl.c Port:4 Si3018
2007-08-24 12:09:12 User.Info 192.168.64.20 GS_LOG: [00:0B:82:0D:FC1][000][FF50][01000037] 455 fxo_ctl.c Port:4 Si3018
I get thousands of the last entry....
