GXW4104 with BLF indication per PSTN port
Discussion in '3CX Phone System - General' started by Bones_Duece, Mar 8, 2013.
  1. Bones_Duece
    Mar 8, 2013
    Is there a way to indicate the status of a port on the 4104 with a BLF on Yealink SIPt38G phones?
    11,111
    329
    Given that BLF's are designed to be associated with the status of extensions, and not trunks, I'm pretty sure that the answer is... no.
    But, someone could surprise us.
  3. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
    This could be possible on 3CX softphone - you can set BLFs to line 10000, 10001, etc.
    Regards
