GXW4108 Template Possible Bug Registration Problem
Discussion in '3CX Phone System - General' started by slynch401k, Sep 13, 2007.
  1. slynch401k
    Jun 29, 2007
    15
    I couldn't get the gateway to register. I used the template to set up the PSTN lines in 3cx but nothing shows up under Line Statue/PSTN.
    If I manually set it up the lines show up.
