- Joined
- Aug 9, 2017
- Messages
- 23
- Reaction score
- 3
Hey Team,
I've been using 3CX for many years, but I'm about to put in my first 3CX Enterprise System which will use HA and in all honesty I just can't get my head around this!
What I need to understand in order to design the HA is if the Private IP Address of the 3CX server stays the same between the two servers. I appreciate the Public IP must be different and we're using NAT which all makes sense, however if we're using the same Firewall but with two Public IP's, then I can't have a rule to go to the same IP even if the machines are using 192.168.10.1 but on separate VLAN's as an example.
How does this all work?
Thanks for your time 3CX Guru's!
Cheers,
Jay
Cheers,
Jay
