Hacker attack
Discussion in '3CX Phone System - General' started by whitewhite, Oct 3, 2011.
  1. whitewhite
    Jul 11, 2011
    20
    Please advise if there is something more I shall do. According to log report, I am having continuous attack from the hacker. Athough the ip had been blocked by the program for certain seconds, but the hacker keeps try the ports for several days.
  2. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
    Configure firewall rule in your router dropping the packets from the hacker's IP.
    You may consider MikroTik RB-750GL as inexpensive (~ € 50.-) router, if don't have one.
    Regards
