handytone 503 configuration
Discussion in '3CX Phone System - General' started by giorgiobusoni, Jun 15, 2011.
  1. giorgiobusoni
    Apr 6, 2011
    32
    i'm trying to cofigure the handytone 503 fxs/fxo gateway to work with 3CX
    I have also a snom 3 working with 3cx and works well
    but with handytone i have a problem configuring outgoing calls on PSTN line.
    here is the configuration:
    PSTN devices:
    genric - handytone 503
    ext: 10001
    incoming calls to: ext 11
    allow incoming calls
    allow outgoing calls
    voipprovider:
    generic
    incoming calls to: ext 10
    ext:
    10: is the snom 3
    11: is the ext for the handytone
    outgoing rules:
    numbers starting with 0 or 3->generic voip provider
    numbers starting with 2->delete first digid and go to handytone 503 pstn
    in handytone config, i configured the FXS port with the account of ext 11 and FXO port with account of 10001
    primary server and outbound proxy both set to the 3cx server
    also set correct zone foor the impedence
    now, this is what happens:
    incoming calls to PSTN number go to phones connected to handytone->OK
    incoming calls on voip number go to snom ->OK
    outgoing calls starting with 0 or 3->done with voip account->OK
    outgoing calls starting with 2->one digit is removed but the call is not forwarded to the requested number, instead internal phones connected to handytone ring->NOT GOOD
    for example, i what to call 3925566778
    if i digit 3925566778 on the snom (ext10) and press the call button, a conversation between ext10 and the 3925566778 will start, using the vOIP number
    if i what to call the 3925566778 using PSTN line, i should digit 23925566778 on the snom (ext10), but in this case, a conversation between the snom(ext10) and the 3925566778 does not start, instead a conversation between the snom(ext10) and the the attacked to handytone (ext11) starts!!!!
    what's the error in my configuration?
  2. giorgiobusoni
    Apr 6, 2011
    32
    this is the LOG:
  3. willow
    willow Member
    Mar 1, 2011
    471
    make sure the stage dialing is set to 1 and not 2.
    also set the ring thru to fxs to no.
  4. giorgiobusoni
    Apr 6, 2011
    32
    PSTN ring trough FXS was set to yes and stage dialing was set to 2. I fixed theese. tomorrow I try again and see if it solves the problem. I'll let you know
  5. willow
    willow Member
    Mar 1, 2011
    471
    I just connect a handytone 503 to a 3cx. Its not the best piece of equipment but gets the job done for a line. If your in the states I can gladly help you out.
