handytone
Discussion in '3CX Phone System - General' started by spec, Jul 31, 2008.
  1. spec
    Sep 8, 2006
    51
    Hi I want to get a handytone and I’m trying to work out what does what. The pc with 3cx on connects to my netgear router with an rj45. The pc has 2 network ports so I think the handytone could plug in to the router or the pc. So with that in mind anyone of them should do that job (I think).
    Now I have one phone line coming in to the house which I want to connect to 3cx. I thought analogue phone port did that job, but what this pstn passthrough port I thought that was a phone port to. But the handytone 286 has 1 analogue and no pstn. So I’ve got something wrong. Or I am I correct maybe not
    Help
    Grandstream ATA Comparison Table
    Feature ................Handytone 286.........Handytone 386..........Handytone 486............Handytone 488..........Handytone 496
    Ethernet Ports .........1 x RJ45 (LAN).........1 x RJ45 (LAN)..........2 x RJ45 (LAN/WAN) .....2 x RJ45 (LAN/WAN)....2 x RJ45 (LAN/WAN)
    DHCP/NAT Router .....No........................No........................Yes .........................Yes.........................Yes
    Analogue Phone Port....1.........................2 .........................1............................1 ......................... 2
    Analogue Line Port.....No....................... No .......................No..........................Yes .......................No
    PSTN Pass-through
    Port.......................No ......................Yes ...................... Yes ........................ Yes ........................No
    Remote Configuration.TFTP/HTTP ............TFTP/HTTP ...............TFTP/HTTP ...................TFTP/HTTP .........TFTP/HTTP
  2. amygoda
    amygoda Member
    Sep 18, 2006
    436
    In Handytone get 503
    but I prefer Linksys SPA3102
    and for IP phone You can get Grandstream
  3. spec
    Sep 8, 2006
    51
    Hi thanks for answering
    I was thinking and still am of getting a linksys spa3102 as I notice in one of the post a 3cx tech guy said they had tested that unit on the 3cx. But when you do a search in this forum all you get is people having problems. So it’s kind of scaring me off a bit. I think I would still like to get one but I’m not sure I could get it running.
    Have you got one and have you had any probs with it
    thanks
  4. amygoda
    amygoda Member
    Sep 18, 2006
    436
    Grand stream is great in ip phone and gxw410x
    but in ata you'll scare more ithan spa3102
    the problem in spa3102 it has a lot of settings
    some people did a mistake
    I'm always say the best thing to solve spa problem is reset to factory set and configu it again
    you'll find it easy and works fine
  5. spec
    Sep 8, 2006
    51
    thanks
  6. amygoda
    amygoda Member
    Sep 18, 2006
    436
    You are welcome
  7. spec
    Sep 8, 2006
    51
    I was just about to buy one when I noticed the word router (Linksys SPA3102 Voice Gateway with Router - VoIP gateway - EN, Fast EN).
    Are they using the word router because it routes your phone calls or is it a pc internet router as well ? ? ?
    I use a Netgear DG834N which I want to continue to use so if it is a pc router would this be a problem for me ? ? ?
  8. galal202
    galal202 New Member
    Jun 23, 2008
    235
    router is an option
    you can use bridge mode not nat
    also grandstream 503 did the same but spa better
  9. francesco
    francesco New Member
    Jun 23, 2008
    102
    only 488 have a fxo port
  10. amygoda
    amygoda Member
    Sep 18, 2006
    436
    Hello francesco,
    503 has fxo,fxs with caller id and router
  11. spec
    Sep 8, 2006
    51
    Thanks all going to go with the SPA3102
    Thanks again
  12. francesco
    Jun 23, 2008
    102
    yes,
    i intend between Handytone 286.........Handytone 386..........Handytone 486............Handytone 488..........Handytone 496
    only 488
  13. amygoda
    amygoda Member
    Sep 18, 2006
    436
    Hello
    Both are grandstream
    The prices are alomst the same
    so why I buy ata without caller id?
