Hard Drives -- RAID controller cache ?
Discussion in '3CX Phone System - General' started by 3cxUsers, Jul 1, 2015.
  1. 3cxUsers
    Jun 26, 2015
    8
    My 3CX server Dell PowerEdge T630 server has lots
    of memory, but a PERC H330 which has no CACHE per
    http://www.dell.com/learn/us/en/04/campaigns/dell-raid-controllers
    http://downloads.3cx.com/downloads/3CX_Phone_System_Operating_System_Specifications.pdf
    does not say anything about how much CACHE a RAID 5 controller should have.
    Does anyone have a RAID 5 controller CACHE
    size recommendation for 16 concurrent calls ?
  2. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
    Should not be important, any size of cache or no cache at all is fine for almost any size of 3CX and completely irrelevant for 16SC, even recording all calls simultaneously. The network load will not exceed 0.5% typically.
