Hard phone connect to 3cx via internet
Discussion in '3CX Phone System - General' started by binary1, Apr 15, 2010.
  1. binary1
    May 4, 2009
    43
    Hi, I've got a windows server on the internet without any firewall.
    Am trying to connect a hard phone (namely the Yealink T20s and T28s) over to the 3CX.
    Can someone explain to me how and what settings I have to put together for it to work? I can connect if I disable the STUN but it's connecting with a local address so when I try calling say the voice mail, I get no sound.
  2. mfm
    mfm Active Member
    Mar 4, 2010
    641
  3. leejor
    11,073
    323
    Is the extension on the same network as the server? Same private IP range, behind a router?
    Never mind, haven't had my morning coffee yet, re-read your post....
    Remote Extensions will almost always have to use STUN unless you are using VPN or a tunnel. What shows up in the 3CX log when you enable STUN and attempt a registration of the set? Do you see anything? I assume that the remote set is behind a router. Is the port number of the set (for example, 5060) unique to that network?
