Hard Phone w/vpn
Discussion in '3CX Phone System - General' started by donbru01, Jun 6, 2012.
  1. donbru01
    donbru01 New Member
    Nov 30, 2011
    134
    Anyone know if exist SIP Hard Phone with inbuild VPN Client IPSEC ?
    No Open VPN
    We have try Model VideoPhone Cisco , and work fine with CUCM ( SCCP) on VPN IPSEC , but it is difficult convert this phone into SIP PHONE !!
    Thanx
    Bruno
    11,293
    361
    The majority of users would probably be running a set, (or more likely sets), through a router that supports VPN, letting it handle the tunnel . Putting a VPN client in a SIP set will probably be rare or very expensive.
    Even for a "one of" location, you may find it more economical to use a VPN capable router, along with a "run of the mill" VoIP phone.
  3. donbru01
    donbru01 New Member
    Nov 30, 2011
    134
    Yes we use this topology for normal connection , we have about 750 Site connected to headquarter with ASA 500 , my request is for special project where i can't use ASA .
    I must connected Hard-Phone inside a LAN is not our property , without use other device .....
  4. albertc
    Nov 21, 2011
    89
    The Cisco SPA525G or Cisco SPA525G2 can be used in a virtual private network
    (VPN) to allow users secure access to the office phone network from remote
    locations or to connect the Internet and use VPN to access the company phone
    network. This feature works on the Cisco SPA525G or Cisco SPA525G2 using
    either SIP or SPCP.
    The phone works with the Cisco AnyConnect VPN client and the following VPN
    devices:
    • Cisco 500 Series Secure Router
    • Cisco 5500 Series Adaptive Security Appliance
    • Cisco Unified Communications 520 Series
    You must configure the SSL VPN device to ensure proper routing of voice data by
    using VLAN and QoS at the end of the SSL VPN server. The following restrictions
    apply:
    • HTTP proxy is not supported.
    • SSL client certificate verification is not supported.
    • CDP and VLAN tagging and QoS for the voice and PC port are not
    supported on the SSL VPN tunnel.
