Hardware recommendation
Discussion in '3CX Phone System - General' started by mamache, Apr 2, 2010.
  1. mamache
    Mar 29, 2010
    I currently have one location running HP Server and Win 2003 server for 30 users.
    Adding a small office as a separate system, 4 phones, 4 lines on a sip trunk (will be used for voice and fax) over an adsl 6m/768.
    Will the following hardware suffice for this?
    Software & Services
    Genuine Windows® 7 Professional, 64bit, English
    AMD Dual Core Athlon™ X2 3250e (1MB L2, 1.5GHz)
    3 Year Basic Service Plan
    3GB DDR2 SDRAM at 800MHz- 2 DIMM
    No Monitor
    Integrated ATI Radeon HD3200 Graphics
    250GB 7200 RPM SATA Hard Drive
    Thanks in advance.
    Integrated 2.1 High Definition Audio
  2. sipero123
    Nov 24, 2008
    94
    Personally I would get a better processor but otherwise this should be adequate providing you don't have call recording enabled.
    Jonathan Hamon
