Has anybody experience about Tenor gateways?
Discussion in '3CX Phone System - General' started by tab, Sep 25, 2007.
  1. tab
    tab
    Aug 10, 2007
    85
    hi,
    I'm testing a Quintum TenorBX-204 gateway but it is not working fine. Registering is OK, incoming calls from PSTN are OK but no outgoing calls. 3cx gets 503 code (service unavailable) from gateway. The gateway have various routing plans, I'm lost between these.
    Can anybody help me to solve it?
    thanks
    tab
  2. super_voip
    Aug 29, 2007
    20
    error codes
    usually error codes in the 500 range are Server errors
  3. ktikoft
    Jun 22, 2007
    59
    I have a DX2010
    it does sound like a routing table issue.
    In the Quintum in advanced mode
    CircuitConfig, Trunk Routing, Hopoff Number Directory1 you need to have all number patterns which match outbound lines
    ie number pattern 0 replacement number 0 etc etc
