Has anybody used Intel Dialogic HMP 3.0 with 3CX?
Discussion in '3CX Phone System - General' started by olren, Sep 26, 2007.
  1. olren
    Sep 25, 2007
    I'm trying to make Attended Transfers work.
    So far no success.
    Any information will be appriciated.
  2. Anonymous
    Anonymous Guest
    Provide link to product and if possible manual.
    We here in AU have been able to make the Dialogic cards work and transfer (well a partner of mine did anyway).
  3. olren
    Sep 25, 2007
    I'm a C++ developer and I'm using Intel Dialogic HMP 3.0 with Global Call API.
    We are an Australian company MESSAGEmanager Solutions http://www.mmanager.com.
    One of our products is a VoiceXML server which integrates with various Analog, ISDN or IP PBX's.
    Currently I'm trying to work with 3CX PBX using above mentions API and Dialogic Service.
    Registration and blind trasfers work fine, but when I try make a Supervised ( Attended) transfer 3CX PBX logs the following error "Cannot build transfer target by DBCfg".
    To make an Attended transfer I make following steps:
    1. Register with 3CX pbx.
    2. Receive a call from a soft phone(1) through 3CX.
    3. Make a new call through 3CX BPX to a soft phone (2)
    4. Attempt to make a Transfer, but get the above mentioned error logged in 3CX Server status page.
    5. Both calls get a SIP 603 message that the transfer declined.
    Any information will be appreciated.
    thank you
  4. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    2,007
    312
    Thanks for your explanation. Can you post more of the log entries pertaining to the transfer? Also could you make a capture so we could review it? Please email it to ng [at] 3cx.com
  5. olren
    Sep 25, 2007
    15:27:36.546|.\CallConf.cpp(120)|Log2|CallControl|CallConf::eek:nIncoming:[CM103002] Call(1): Incoming call from 100 (Ext.100) to sip:103@172.22.250.28:5060
    15:27:36.625|.\Call.cpp(266)|Log2|CallControl|CallLegImpl::eek:nConnected:[CM103001] Call(1): Created audio channel for Ext.100 (172.22.251.30:49428) with Media Server (172.22.250.28:7024)
    15:27:36.625|.\CallStrategies.cpp(705)|Log2|CallManager|StratInOut::eek:nConnected:[CM104005] Call(1): Setup completed for call from Ext.100 to Ext.103
    15:27:36.625|.\Call.cpp(266)|Log2|CallControl|CallLegImpl::eek:nConnected:[CM103001] Call(1): Created audio channel for Ext.103 (172.22.251.14:49152) with Media Server (172.22.250.28:7026)
    15:27:41.359|.\CallConf.cpp(120)|Log2|CallControl|CallConf::eek:nIncoming:[CM103002] Call(2): Incoming call from 103 (Ext.103) to sip:102@172.22.250.28
    15:27:41.734|.\CallConf.cpp(178)|Log2|CallControl|CallConf::eek:nProvisional:[CM103003] Call(2): Ext.102 is ringing
    15:27:45.390|.\Call.cpp(266)|Log2|CallControl|CallLegImpl::eek:nConnected:[CM103001] Call(2): Created audio channel for Ext.103 (172.22.251.14:49154) with Media Server (172.22.250.28:7028)
    15:27:45.390|.\CallStrategies.cpp(705)|Log2|CallManager|StratInOut::eek:nConnected:[CM104005] Call(2): Setup completed for call from Ext.103 to Ext.102
    15:27:45.406|.\Call.cpp(266)|Log2|CallControl|CallLegImpl::eek:nConnected:[CM103001] Call(2): Created audio channel for Ext.102 (172.22.250.39:49362) with Media Server (172.22.250.28:7030)
    15:27:50.062|.\CallStrategies.cpp(301)|Log2|CallManager|StratLink::Transfer:[CM104002] Call(2): transfers Ext.102 from Ext.103 to sip:100@172.22.250.28:5060
    15:27:50.062|.\CS_Transfer.cpp(96)|Critical0|CallManager|StratTransfer::initialize:[CM008004] Call(2): Cannot build transfer target by DBCfg
    15:27:50.062|.\CallStrategies.cpp(68)|Log2|CallManager|CallStrategy::Transfer:[CM104000] Call(2): transfer failed
    15:27:50.156|.\CallStrategies.cpp(264)|Log2|CallManager|StratLink::eek:nHangUp:[CM104001] Call(1): Ext.103 hung up call; cause: BYE; from IP:172.22.251.14
    15:27:50.171|.\CallStrategies.cpp(264)|Log2|CallManager|StratLink::eek:nHangUp:[CM104001] Call(2): Ext.103 hung up call; cause: BYE; from IP:172.22.251.1
