Has anyone succesfully used the Digital Receptionist
Discussion in '3CX Phone System - General' started by chrisjr, May 1, 2007.
  1. chrisjr
    Jan 23, 2007
    21
    Has anyone successfully used the digital receptionist? If so could you let me know how voip provider you used, what phone, and what settings you had. I've gotten ring groups and everything else to work perfectly but whenever I add a digital receptionist it will pick my calls up and then just disconnect them. It will do this even if the calls are picked up by one of my phone. The conversation will last 10 seconds and then it will just disconnect the user.
    Chris.
  2. tcgmuc
    Mar 14, 2007
    59
    Hi Chris,
    DR ist working in our office.
    Our Equipement for testing:
    - Windows XP Pro
    - 3CX
    - Sipgate.de as SIP-Provider
    - Linksys/CISCO Phones
    - Siemens IP-Phones
    Can you make or get any "normal" calls, or do you have the problem with the 10s every time ?
    Greethings,
    Michael.
  3. no1daag
    Feb 8, 2007
    29
    Working fine for me
    Windows XP home :cry:
    3cx
    Wireless net
    Voip : Woize.com
    3CX Phones on laptop and three computers
    Nokia N80
  4. chrisjr
    Jan 23, 2007
    21
    I have broadvoice, grandstream budgetone phone, and using a cingular cell phone to test the system out. I can make inbound and outbound calls just fine without it timing out after ten seconds. How do you have your digital receptionist setup?? Does it ring to a ring group?
  5. chrisjr
    Jan 23, 2007
    21
    My server logs are below as well.... Doesn't make sense to me.
    11:25:22.343 StratLink::eek:nHangUp Call(C:6): Ln:10000@Broadovice1 hung up call; reason: BYE
    11:25:15.765 CallLegImpl::eek:nConnected Call(C:6): Created audio channel for Ext.101 (192.168.2.4:5004) with Media Server (192.168.2.6:7018)
    11:25:15.765 StratInOut::eek:nConnected Call(C:6): Setup completed for call from Ln:10000@Broadovice1 to Ext.101
    11:25:15.093 CallConf::eek:nProvisional Call(C:6): got response from 101
    11:25:09.796 MediaServerReporting::DTMFhandler from 'PhoneServer:0/MediaServer':DTMF (RTP) from 147.135.20.250:14042 arrived. in-band DTMF tone detection is turned off.
    11:25:05.687 CallLegImpl::eek:nConnected Call(C:6): Created audio channel for Ln:10000@Broadovice1 (147.135.20.250:14042) with Media Server (67.53.129.195:9000)
    11:25:05.671 CallConf::eek:nIncoming Call(C:6): Incoming call from Ln:10000@Broadovice1 to sip:2627371044@192.168.2.6
  6. no1daag
    Feb 8, 2007
    29
    My DR have 3 chooiche
    1 to ringgroup with 2 ext
    2 to ringgroup with 3 ext
    3 to ext /voicemai
    Works fine. Use my own soundfile
    Nemas problemas
    Use only Voip provider to my 3cx
  7. ITWorks
    ITWorks New Member
    Apr 7, 2007
    121
    Disconnect on Digital Receptionist Transfer
    I have the same problem when using the Digital Receptionist although it had been working previous to today. The line is disconnected with incoming Broadvoice IP calls seconds after transferring to the chosen extension. Everything works fine when I take the Digital Receptionist out and have calls go directly to an extension. This does not happen with PSTN calls to Grandstream Gateway.
    Windows Server 2003
    Broadvoice VSP
    Grandstream Gateway
    Cisco 7941 phones
    My logs from a failed Digital Receptionist transfer:
    14:58:12.385|.\CallConf.cpp(95)|Log2|CallControl|CallConf::eek:nIncoming:Call(C:4A): Incoming call from Ln:10001@Broadvoice to sip:26xxxx0025@10.10.30.3
    14:58:12.432|.\Call.cpp(260)|Log2|CallControl|CallLegImpl::eek:nConnected:Call(C:4A): Created audio channel for Ln:10001@Broadvoice (147.135.12.248:38692) with Media Server (10.10.30.3:9002)
    14:58:16.557|.\SLServer.cpp(303)|Log2|MediaServer|MediaServerReporting::DTMFhandler:from 'itserver1:0/MediaServer':DTMF (RTP) from 147.135.12.248:38692 arrived. in-band DTMF tone detection is turned off.
    14:58:21.369|.\CallConf.cpp(152)|Log2|CallControl|CallConf::eek:nProvisional:Call(C:4A): got response from 4414
    14:58:29.182|.\CallStrategies.cpp(721)|Log2|CallManager|StratInOut::eek:nHangUp:Call(C:4A): Call from Ln:10001@Broadvoice to 4414 has been terminated
    IVR Log:
    14:58:21.198|0c7c|c:\svn\src\ivr\vxmlivrservice\pbxmedia\IPbxMediaImpl.h(181):IvrService, IMSEndPointListenerIVR::endOfPlayedFile(), Fire '2' played
    14:58:21.198|0638|.\api\VXItelImpl.cpp(167):IvrDll, VXItelImpl::Impl::TransferBridge(), TransferBridge: 01EBBC20
    14:58:21.198|0638|.\api\VXItelImpl.cpp(120):IvrDll, VXItelImpl::Impl::IntrnTransfer(), Bridge transfer to sip:4414@127.0.0.1
    14:58:29.197|0c7c|.\PbxMedia\IPbxMediaImpl.cpp(54):IvrService, IPbxMediaImpl::stopSession(), Ivr_EndSession called
    14:58:29.197|0638|.\api\VXItelImpl.cpp(138):IvrDll, VXItelImpl::Impl::IntrnTransfer(), Error! Error of 'From_9072243326_To_1000_Menu_1000_#0' session transferring to sip:4414@127.0.0.1. Status: NEAR_END_DISCONNECT. Transfer error. Session stopped
    14:58:29.197|0638|.\api\VXItelImpl.cpp(98):IvrDll, VXItelImpl::Impl::Disconnect(), Disconnect occurred
    14:58:29.197|0c7c|.\PbxMedia\IPbxMediaImpl.cpp(35):IvrService, IPbxMediaImpl::~IPbxMediaImpl(), IPbxMediaImpl destroyed
    14:58:29.197|0c7c|.\PbxMedia\IVRServer.cpp(83):IvrService, IVRDeleteHandler(), IVRHandler:0000000A removed
  8. swallservices
    May 7, 2007
    6
    From looking at your server log quoted below one thing stands out to me:
    With In-band DTMF tone detection turned off BroadVoice will be unable to pass the tones generated by key presses to your 3CX Digital Receptionist. As for why the call is terminating it's BroadVoice that's ending the call, not 3CX. There is a chance that since in-band DTMF tone detection is turned off that when BroadVoice hears a key press and knows it can't pass on the tone to 3CX it just ends the call, but that's just speculation on my part.
    Do you experience the same problems with incoming calls to a digital receptionist from a PSTN gateway or another VoIP provider other than BroadVoice? If not, you might want to contact BroadVoice to help resolve this issue.
  9. silentfun
    silentfun Member
    Dec 11, 2006
    364
    I have set up following system
    3 extensions 100 IPPhone and 200 IPPhone and 301 (not a real phone)
    3 VoIP Providers 1001 sipgate.de and 1002 sipgate.co.uk and 1003 3.Provider
    2 DR 900 ( office open ) and 901 ( office closed ) and 903 (support request)
    if a inbound call comes from 1001 it is frowardet to 900 or 901
    both (900 and 901) DR have a greeting
    900 say we connect to the next free person and forward to 100 and/or 200
    901 say office is closed the office time is bla ...bla.. thx for calling. and forward to DR 903
    903 say If you have a emergency or a premium support contract please press "8" on your phone
    he repeat this until the caller hang up
    if the caller press "8" the DR 901 forwards the call to extension 301
    ext 301 is configured do forward the caller to a cellphone via line 1003
    there my handy is ringing
  10. ITWorks
    ITWorks New Member
    Apr 7, 2007
    121
    disconnect after 10 seconds
    Thank you SwallServices.
    I do not believe the problem is that DTMF tones are not being detected. The digital receptionist transfers the call to the proper extension after the extension has been selected by DTMF. The call is then disconnected 10 seconds after transfer. I can see the transfer below:
    I am sure the answer is in the IVR log below but I can not determine the cause.
    14:58:29.197|0638|.\api\VXItelImpl.cpp(138):IvrDll, VXItelImpl::Impl::IntrnTransfer(), Error! Error of 'From_5055553326_To_1000_Menu_1000_#0' session transferring to sip:4414@127.0.0.1. Status: NEAR_END_DISCONNECT. Transfer error. Session stopped
    It does not do this if the call is not transfered. It does not do this with calls coming in from the PSTN Gateway.
    The strangest thing to me is that it did work properly for a few days and just has not worked since with no conifuration changes.
  11. ITWorks
    ITWorks New Member
    Apr 7, 2007
    121
    Digital Receptionist calls hang up after transfer
    One additional piece of information I am unable to explain.
    When calls come into the Digital Receptionist via the PSTN gateway the status shows "connected" in Line Status.
    When calls come into the Digital Receptionist via the VOIP gateway the status shows "calling" in Line Status.
  12. silentfun
    silentfun Member
    Dec 11, 2006
    364
    i think the difference between connected & calling is if the call comes from the pstn it is connectet pysical wile a sip call is as long calling until it is established or rejectet.
    i do much testing atm and sometimes i wonder but after some thinking about i find out why most things that happens are not bugged. there is mostly a reason why.
    excuse my bad english
  13. ITWorks
    ITWorks New Member
    Apr 7, 2007
    121
    digital receptionist transfers fail
    Chrisjr,
    Have you been able to solve this problem yet? I have spent many hours on it. It is the only thing keeping us from implementing 3CX as our school IP PBX.
    Calls coming in from Broadvoice drop when ringing an extension when transfered by digital receptionist. Never happens with calls coming in on PSTN gateway or when not using digital receptionist. Logs look the same for PSTN calls as IP calls.
    Mark
  14. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    Re: Digital Receptionist calls hang up after transfer
    Yes, this explains a lot. The problem is that your VOIP gateway doesn't support re-INVITEs and/or 'Replaces:' header. Try to turn off that options in Advanced options of VOIP gateway settings - and it should help.
  15. ITWorks
    ITWorks New Member
    Apr 7, 2007
    121
    Thanks Archie,
    This did not make a difference. The extension is ringing after DR transfer and the line status shows calling. The PSTN line shows connected when the extension is ringing after DR transfer.
    Wouldn't my 3CX machine be my VOIP gateway? I connect through a T1 and router to the Internet and BroadVoice.
    Mark
  16. Yuriy
    Aug 8, 2007
    Hi - same issue with receptionist
    I have the situation with non working receptionist extension on your Free version.
    I have downloaded a free version by the link, http://www.3cx.com/downloads/3CXPhoneSystem31.exe
    Installaed it, and did a setup:
    - configured three extensions 100,101,102.
    - two of them grouped by a RingGroup (101 and 102) with extension 800;
    - Created the receptiinist for extension 801 with the *.wav wellcome file uploaded (PCM, 8 bit, 8 KHz mono)
    > Even for pressins 1 - connect with first extension
    > Even for pressing 2 - connect with a Ring Group
    Registered all three extension, and tried to dial to Rreceptiinist
    16:39:31.890 StratInOut::eek:nCancel [CM104009] Call(9): Call from Ext.103 to 801 has been terminated
    16:39:31.875 CallConf::eek:nIncoming [CM103002] Call(9): Incoming call from 103 (Ext.103) to sip:801@x.x.x.x
    Second issue - after I've restarted 3CX* services, the call does not
    go at all:
    16:41:13.250 StratInOut::eek:nHangUp [CM104007] Call(10): Call from Ext.103 to 101 has been terminated by Ext.103; cause: CANCEL; from IP:x.x.x.x
    16:41:08.515 gt;>:Illegal message rejected: ParseBuffer.cxx:948, Parse failed unexpected eof in context: From
    16:41:08.390 CallConf::eek:nIncoming [CM103002] Call(10): Incoming call from 103 (Ext.103) to sip:101@x.x.x.x
  17. Ralph
    Ralph Member
    Jun 28, 2007
    417
    We are using the following:
    3CX Server:
    OS: Windows Server 2003 SP2
    RAM: 1 Gig
    CPU: P4 3 Ghz
    Phones:
    Polycom Soundpoint IP 501s
    Grandestream GXP 2000
    Grandstream Handytone 486
    All phones are on the same subnet except the Grandstream Handytone which is connected via a VPN from a satalite office.
    Digital receptionist (we have a total of 7 set up) all seem to work fine.
    Take care
  18. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Hi Yuriy,
    Please enable the log level to "Verbose (only used for debugging purposes)". Restart all 3cx services or restart 3cx box. Then post the log here again.
  19. Ralph
    Ralph Member
    Jun 28, 2007
    417
    Hi Yuriy,
    You mentioned that you set up extensions and a ring group but not that you set up a digital receptioist.
    Did you set up a digital receptionist and did you configure your incomming lines to be answered by the digital receptionist?
    Take care,
