have some way to make PeopleCall working when calling out
Discussion in '3CX Phone System - General' started by jesusfernandez, Aug 21, 2007.
  1. jesusfernandez
    Aug 20, 2007
    When calling outside trough PeopleCall provider, allways get the error message.
    But if I use a device with code G729x, all is OK
    Can I have some alternative to fix this problem??
  2. Mirzab
    Mirzab Member
    Jul 22, 2007
    400
    From a brief review on their site I saw this:
    Most of the support information is in Spanish (I believe) so I cannot find much more.
    3CX does not support either codec to the best of my knowledge. On my server I see the following: G.711u, G.711a, GSM-FR and Speex.
    I cannot offer any alternatives. Maybe another Forum member might be able to assist more.
