Have to keep on registering the line to receive phone calls
Discussion in '3CX Phone System - General' started by dtv, Sep 19, 2008.
  1. dtv
    dtv
    Mar 12, 2008
    I am not able to receive phone calls unless I register the line or make an outbound phone call.
    If I do not make a call out or register the line, the inbound calls will fail. The line will drop within a min.
    I tried to reduce the value in Time between registration attempts (in seconds) to 600, and the problem is still there.
    Once an inbound call failed, I will receive an email from my VOIP provider telling me that a call to my DID number has failed . They received 'CHANUNAVAIL' when attempting to route the call to my server or device.
    I tried two different voip providers, and the same situation happenned both times.
    I am testing with the free 3CX version 6.0.806.0.
    How do I keep the line from dropping? Is it a firewall problem (my firewall test passed)? Is is a stun server problem?
    Thank you,
    Dan
  2. radcomp
    Aug 21, 2008
    35
    just make sure that your router has these ports open 5060 5080 and 9000 to 9007
    also make sure that windows firewall on the PC that 3cx is installed on, is disabled
    i had the same problem and this seemed to have fixed it
    Regards,
    Josh
  3. dtv
    dtv
    Mar 12, 2008
    Josh,
    Thanks, my firewall was the problem.
    dtv
  4. wzaatar
    Aug 1, 2007
    90
    You can also ask the 3cx to re-register every 2-3 minutes.
    Cheers,
    W.
  5. Discovery Technology
    Apr 19, 2008
    278
    Most firewalls have an active connections timeout (both UDP and TCP - depending upon the compplexity of the firewall) - you might want to check your UDP timeout setting for your SIP registrations as it may be disconnecting you in the background as well.
    Active connections timeouts are good settings to keeep the firewall running efficiently, however they can give you some unexpected results if you don't modify them for your registrations and audio call traffic.
    Cheers, Brendan
