Haven't received the 3CX Welcome Email
Discussion in '3CX Phone System - General' started by Silvano Avilan, Jan 31, 2018.
  1. Silvano Avilan
    Jan 31, 2018
    I did not receive the 3CX welcome email??
  2. jimbo59
    jimbo59 Member
    Nov 17, 2017
    358
    77
    Did you do a test email first?
  3. Silvano Avilan
    Jan 31, 2018
    I opened this account for ask, this for now
  4. jimbo59
    jimbo59 Member
    Nov 17, 2017
    358
    77
    That statement means nothing
  5. Silvano Avilan
    Jan 31, 2018
    this goes out and mail does not arrive
  6. Silvano Avilan
    Jan 31, 2018
    how I can?
  7. techdummy
    techdummy New Member
    Sep 22, 2017
    139
    8
    I believe you are using V15.5
    Go to Settings > Email
    Check and confirm that all the entries are correct.
    Once you have confirmed everything is correct, click on "Test".
    You will receive a confirmation about whether everything is working fine or not.
    If it isn't working, follow this link and configure it correctly.
    https://www.3cx.com/blog/docs/gmail-mail-server/
    Here the email account used is Gmail, if you are using your official email, then there is no need to configure 2nd part mentioned in the post.
    apostolis_3CX likes this.
  8. apostolis_3CX
    apostolis_3CX Support Team
    Nov 1, 2017
    149
    15
    As techdummy suggested you should first check and verify that the PBX is able to send notification emails. Follow the guides and if further assistance is needed we are more than happy to help.
  9. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    4,404
    282
    Once you make sure that your email is working, navigate to the Extensions Tab of the PBX and make sure that your extension has a valid email address configured. Then select it and click on the welcome email button on the menu above the extensions.
