Having issues installing V15 on Windows
Discussion in '3CX Phone System - General' started by daleirvine12, Sep 22, 2016.
  1. daleirvine12
    Sep 22, 2016
    Everytime I try and install V15 on my Windows PC, it comes up with the following error. Can anyone shed some light on this and help with the install?
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,783
    563
    Could you please send me a personal message and attach the PBX config tool log which can be found at C:\ProgramData\3CX\Data\Logs and send me the file called PbxConfigTool.log
    also open a cmd and perform a ipconfig /all and send me that screenshot as well.
  3. daleirvine12
    Sep 22, 2016
    Hi Yinnish,
    I have sent you a Private Message with a dropbox link for the requested information and log.
