Having problems with firewall
Discussion in '3CX Phone System - General' started by mevans91, May 29, 2017.
  1. mevans91
    May 29, 2017
    Hi everyone,
    I'm having problems with my firewall configuration. I have forwarded ports 9000-9500 to the 3cx server (at 192.168.1.22).
    When I run the firewall checker, about 10% of the ports randomly fail the firewall test.
    For example, on test 1 ports 9019-9022 (and a bunch of others) will fail but then on test 2 they'll be fine but 9022-9043 will fail instead.
    Any ideas as to what is going on, or what I should check?
    Thanks,
    Matt
  2. pact
    pact New Member
    Dec 16, 2009
    204
    37
    Hi Matt,
    What router/firewall are you running?
  3. Zacharias_3CX
    Zacharias_3CX Support Team
    May 4, 2017
    32
    Hello @mevans91
    It would be very helpful if you show us what you have configure as port forward to your firewall. If it is possible add a screenshot.
  4. mevans91
    May 29, 2017
  5. Zacharias_3CX
    May 4, 2017
    32
  6. mevans91
    May 29, 2017
    Hm. Okay.
    I'll see if I can get wireshark to work, I haven't used it in linux before.
    Matt
  7. StefanW
    Jun 2, 2009
    1,218
    89
  8. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,416
    277
    I had this issue with my Miktrotik until a fairly recent firmware update. Port failure was random but system always seemed to work fine and stable.
  9. OCWI
    OCWI New Member
    Jan 17, 2017
    161
    46
    Any SIP ALG involved anywhere? Disable that, it may also be worth a call to your ISP to ensure your modem is in "STRAIGHT bridge" mode. For some reason ISP's lately have internally defined a difference between bridge mode and straight bridge mode.
  10. DSXDATA
    DSXDATA New Member
    Oct 20, 2015
    174
    60
    ALG will consistently break, not a likely cause of random behavior. Might be an aggressive intrusion detection feature on the router. That router has an integrated VOIP client which can most certainly wreak havoc. If you can put it in bridge mode and use your own "known-good" router, you will probably be happier.
  11. OCWI
    OCWI New Member
    Jan 17, 2017
    161
    46
    In our experience the ISP's ALG is almost always the cause of random behavior. In our are we have Charter/Spectrum.
