Having to wait to enter ext til DR is finished
Discussion in '3CX Phone System - General' started by css, Feb 7, 2008.
  1. css
    css
    Aug 15, 2007
    21
    When someone calls in my digital receptionist answers, but if you try and enter someones extension before the end of my DR you just get a invalid enter. I was wondering if there is a way, or a setting somewhere that will allow someone to call in and as soon as the DR picksup enter someones ext and be transfered to that ext imediately.
    Thank you in advance for any helpful suggestions.
  2. William400
    William400 Well-Known Member
    Aug 21, 2006
    1,005
    I have tried this using the 5.1 version and as soon as the DR picks up (within 1 second) I am able to perform the action required, without the need to wait. What version are you running?
  3. landfiets
    landfiets New Member
    Jul 17, 2007
    243
    That's right. You must be able to dial the extension immed. when you hear the DR
  4. css
    css
    Aug 15, 2007
    21
    I am using version 5.0.3790.0
    When I check for updates it says I am up to date on it.
    If it doesn't come back with invalid entry. It just treats it like you didn't type in any extension.
  5. Wardy
    Wardy New Member
    Sep 18, 2007
    110
    Version 5.1 is a Beta and can be downloaded from the forum
  6. aguilar
    aguilar New Member
    Jul 19, 2007
    169
    are the ports ok?
  7. eddietang
    Oct 3, 2007
    31
    What VoIP gateway are you using? Could be just a firmware issue.
  8. nb
    nb Support Team
    Jun 7, 2007
    2,147
    173
    Guys
    We have performed a fix to this which will be available soon and will be solved by performing an update to the 3CX PBX. This will enable you to instruct IVR to End the call after a specific timeout. Basically in the Timeout options at the bottom of each DR, you will notice that the "no action" option will be replaced by an "end call".
    This will be released very soon. Probably today.
