When I setup a PSTN device it came up unregistered. So I used the trunk. Teliax. for outbound calls.
Here is the server log for a outbound call.
10:58:52.796 [CM503016]: Call(34): Attempt to reach <sip:1805*******@192.168.xx.xxx> failed. Reason: Not Found
10:58:52.796 [CM503014]: Call(34): No known route to target: <sip:
[email protected]>
10:58:52.796 [CM503010]: Making route(s) to <sip:1805*******@192.168.xx.xxx>
10:58:52.796 [CM505001]: Ext.14: Device info: Device Identified: [Man: Linksys;Mod: SPA Series;Rev: General] Capabilities:[reinvite, no-replaces, able-no-sdp, recvonly] UserAgent: [Linksys/SPA942-5.1.15(a)] PBX contact: [sip:
[email protected]:5060]
10:58:52.781 [CM503001]: Call(34): Incoming call from Ext.14 to <sip:1805*******@192.168.xx.xxx>
