Having trouble with extensions
Discussion in '3CX Phone System - General' started by virtual23, Feb 16, 2014.
  1. virtual23
    Feb 14, 2014
    Some of my extensions are not working even though they say they are
    666 = this call cannot be completed please try again later?
    777 = Same as above
    all others seem to be working can anyone shed any light for me what i may of left out even though i have checked everything?
    10,355
    223
    There may be a number conflict, but check the 3CX server log. That should show what is going on.
  3. virtual23
    Feb 14, 2014
    nothing in the logs
  4. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,061
    56
    Some more detail is needed as while you may understand the full extent of the symptoms, a statement such as "they are not working" is not very telling.
    1. You indicated that somehow or another the extensions in question got "this call cannot be completed........". Was this message for calls being made by the extensions themselves or calls to the extensions?
    2. Can the extensions in question make internal calls, extension to extension?
    3. Are the extensions enabled? Look for the check box under the extension in the "other tab".
    4. Extension 777 is normally reserved for the echo test and can only be accessed by the dial code *777. I do not know if this can be changes as this is a system extension.
    5. What is extension 666? What is it used for and is there a phone attached?
    By virtue of the fact that there was a message is indicative that something happened as the phones did not generate the message, but rather 3CX or perhaps your provider did. The server activity log should reflect the details. Perhaps you looked in the server event log....which will not show this level.
  5. virtual23
    Feb 14, 2014
    666 is the answer phone service
    anything to do with ivd or anything isn't working
