- Joined
- Jul 3, 2011
- Messages
- 4
- Reaction score
- 0
Good Morning,
Wondering whether you can help me i have set up an internal phone system for the lake i work at so we have communication between the Shop, Bar, Office and cable dock and it works perfectly the ext. are 10,11,12,13 with 12 being the shop!
i haven't had any issues with the set-up and it was very easy to do once i had worked out the phone provisioning.
i would like to expand it so i have setup up skype connect and have user id, password, online number and buisness skype name, i have inputed these details into the system and it shows ports 10000 is registered to skype in the ports tab, i have also forward all incomming calls to ext.12(shop) but that is where i have started to have a problem, if i try to call in using the online number or the skype name it will ring twice and then cut off but i get nothing at the phone end!
have you got any idea what i have done wrong or what i haven't done
Regards
Dave
Regards
Dave
