Headphone Set Won't Work With 3CX Phone System
Discussion in '3CX Phone System - General' started by se_vnt3, Nov 24, 2012.
  1. se_vnt3
    Nov 15, 2012
    5
    My C-Media USB Headphone Set doesn't work with 3CX Phone System but works perfectly well with other programs such as Skype and Windows Media Player.
    Why is that?
  2. markshehan
    markshehan New Member
    Nov 14, 2012
    141
    I am guessing you mean the 3cx phone for windows and not the 3cx phone system (PBX)?
    Have you tried going into the advance settings on your profile and changing it.
  3. jpillow
    jpillow Well-Known Member
    Jun 20, 2011
    1,342
    When you say it doesnt work, are you not getting any audio nor sending? what eactly ishappening when you try to use the headset?
  4. sigma1
    sigma1 Active Member
    Nov 20, 2009
    542
    Assuming you are talking about the Windows 3CX Phone, make sure that it has exclusive use of the Audio devices, check under the settings and make sure that you specified correctly the sound devices to use.
