Heads up: "Configure backup rotation" not saved
Discussion in '3CX Phone System - General' started by mcbsys, Mar 17, 2017.
  1. mcbsys
    mcbsys New Member
    Oct 8, 2008
    191
    17
    In v15 SP5, under Backup and Restore > Backup Schedule, if you use the buttons to change Configure backup rotation, the value is not saved when you click OK. You may think you have increased the value from 1 to 7 or 14, but you have not. I only discovered this after almost two weeks of missing backups.
    If you manually type the Configure backup rotation value that you want, it will be saved when you click OK. Re-open the Backup Schedule window to double-check.
    Update It seems this is an issue with Firefox (version 52.0). If you use the spinner in Chrome (version 57.0.2987.110), the value "sticks" when you click OK.
    #1 mcbsys, Mar 17, 2017
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,400
    535
    Hello @mcbsys
    I can confirm after trying out on my machine that the issue is happening with the Firefox browser. Please use google chrome as we investigate this issue.
    Thanks for reporting and sharing your solution.
    mcbsys likes this.
  3. Tomas Raska
    Aug 18, 2017
    59
    6
    Any news?
    I tried it today in Firefox and not working.
    We have latest 15.5 3cx
    Edit: Only arrows not working in Firefox
