Headset recomendations?
Discussion in 'Windows' started by dbergsma, Jul 7, 2009.
  1. dbergsma
    Oct 27, 2008
    39
    I love the idea of a softphone - however, my limited testing seems to have poor quality results. I would suspect (but don't know) that his has more to do with the headset than softtphone.
    Any recomendations on anything that sounds reasonably close to a hardphone?
    Cheers
  2. bluetel2
    bluetel2 Member
    Oct 16, 2008
    377
    8
    hello,
    hmm there is not recomendations for headset. In one company we have headset which cost 10€, and it's work good.
    we can suggest to check your computer or your network. softphone have need good sound card, and good computer, if notn in fact the quality will poor.
  3. Borsoock
    Borsoock New Member
    Apr 8, 2007
    149
    Go for Plantronics! If you want to be independed from computer's sound card, buy USB model.
