Health Monitoring
Discussion in '3CX Phone System - General' started by Gavin Hill, Sep 5, 2017.
  1. Gavin Hill
    Aug 14, 2017
    9
    Is there a way to integrate our NMS tool (Nagios) with 3CX to monitor metrics like phone registration, recording space, etc. I have a client who often has all their phones de-register now and then and it would useful to be able alert on such events.
    timmy.gielen likes this.
  2. Panayiotis_3CX
    Panayiotis_3CX Support Team
    Apr 26, 2017
    165
    7
    Hello @Gavin Hill,
    Notifications can be sent (via email) from the Management Console. There are a number of events to select from, including extension registration change, and recording quota.
    To select the events that are sent, navigate to the Management Console >> Settings >> Email >> Notifications >> Events.
    To enable notifications for the recordings quota - Management Console >> Recordings >> Quota. Here you have the option to select in which quota percentage the email will be sent.
  3. Gavin Hill
    Aug 14, 2017
    9
    Thanks for that response. It's very hard for machines to parse notification e-mails though, I was wondering if there was a more reliable and simple method to integrate the 3CX platform with a traditional NMS (via syslog, SNMP, etc.)
  4. TreuOrga - JM
    May 9, 2017
    7
    It is possible to get some countstates like active calls or active extensions on shell level? If yes we can install a nagios client and write some checks on our own.
