Hearing static over the IP phone
Discussion in '3CX Phone System - General' started by optionderek, Aug 6, 2010.
  1. optionderek
    Jun 29, 2010
    11
    Hi all, we had static over the phone while calling. Currently we are using the Polycom spip 331. Did anyone know where the static from and how to fix it? Thank you.
    11,285
    360
    Not a lot to go on.
    Is there still static, or just one time. Only on one phone? Calls to other extensions or outside calls, if so PSTN Gateway or VoIP provider? Did this just start or has it been this way since day one? Intermittent ?
  3. optionderek
    Jun 29, 2010
    11
    it happen on all 40 phones. sometime static, sometime echo. sometime is good ????? tks.
  4. leejor
    11,285
    360
    On internal AND externals calls? When did it start, were there changes to your network about the time it began?
