heavy CPU Usage on Dual-Core AMD Opteron 3GHz
Discussion in '3CX Phone System - General' started by dubbeles, Aug 4, 2011.
  1. dubbeles
    Aug 4, 2011
    Hi there,
    I'm currently evaluating the commercial version with 4x :
    • server: AMD Dual-Core Opteron (3GHz / 3Gig RAM) / Windows Server 2003 / dedicated 3CX Server
      clients: latest Intel Core i5 with 8Gig RAM / 3CX Phone software
      network: 1Gig
    ... and I notice the following:
    • when 2 phones are connected, the 1st Core is higher it's workload from 3% to 95%
      when 2x 2 phones are connected, the 2nd Core higher it's workload from 1% to 90-95%
      when a client is on hold, the music on hold is very bad. Not even something of a song ..
      we have a very good performing 1Gig network
    QUESTIONS:
    • does anybody have experience with AMD processors for this environment?
      Is the workload per Core normal (90-95%)
    thanks,
    Hans J.
  2. nb
    nb Support Team
    Jun 7, 2007
    2,147
    173
    Is this a virtual machine?
    We have never had this problem before. on the power you are mentioning you can make hundreds of sim calls. Now you cannot even barely make 2.
    Does this Spike and go down or remain constant until the call is terminated?
    Something is very wrong with the machine I would say. What other applications you have on this computer?
    Do you have recording on? (edit extensions options)
    Do you have PBX delivers audio? (edit extensions / options)
    quick test you can do
    Try installing 3CX quickly on the I5 client computer - see what happens..
  3. willow
    willow Member
    Mar 1, 2011
    471
    that cant be normal. I have a few installs on xp pro machines with 10 to 15 calls at a time and the cpu usage never moves. a box like that should be able to handle alot more.
  4. mylove4life
    mylove4life New Member
    Jan 7, 2010
    165
    I too have almost the extact same setup and never had a problem. I have never used more than 10 calls at once but the server was at less than 3% when doing that...
