Heavy echo in my incoming calls with Grandstream
Discussion in '3CX Phone System - General' started by Halea, Mar 17, 2008.
  1. Halea
    Halea New Member
    Jan 5, 2008
    151
    All of a sudden on one of my PSTN lines I am having heavy echo today. Precisely I can hear the other party very well with no echo or any problems, but everything I say comes back to me extremely clear and loud with a 0.5 to 1 second delay.
    This is on my HT488 connected line. I checked the line out with an analog phone connected directly to it. It's "pin drop" quality, I've never had any problems with my provider in this many years, and there is no problem with the line itself now.
    Any ideas where I should start my troubleshooting?
    Halea
  2. h2009
    h2009 Member
    Mar 15, 2008
    447
    Re: Heavy echo in my incoming calls
    After many years experience with my ISDN line - echo, noise, calling problems either came from one of two things:
    The hardware in my case pbx system (static charge normally built up)
    Or BT (line provider) - a problem on there end.
    Can i suggest for you to restart everything, maybe give it 10 minutes cool down period, to clear any capacitor charge, and also calling your telephone provider to see if there is a problem in your area - ask them to run a trace on your line.
  3. h2009
    h2009 Member
    Mar 15, 2008
    447
    Have you managed to sort this problem out?
    It seems like im having the same problem when i call inbound using sipgate - the others i've yet to test.
    If i call from an ISDN line/mobile to VOIP - i can hear my self speak in delay - and the other person crackles alot.
    Im going to run a few more test to see if i can narrow down why its happening.
  4. h2009
    h2009 Member
    Mar 15, 2008
    447
    Ok - both sipgate and voiptalk the results are the same:
    Calling from a UK mobile phone / landline (person A) to computer software phone (person B)
    Person B can hear, and speak without problems of echo going outbound to person A.
    Persona A can hear themself echo when they speak.
    Calling from VOIP (person C) to UK landland (person D)
    Person C cannot hear person D clearly.
    Person D can here a very digitalized sound from person C - i.e. choppy.
  5. h2009
    h2009 Member
    Mar 15, 2008
    447
    Hmm - after trying more testing - im think it must be my hardware somewhere along the line, every provide (voip) has the same problem to a degree or another.
    Can anyone help shed some light on this?
  6. h2009
    h2009 Member
    Mar 15, 2008
    447
    Still having this same problem - anyone else experiencing this?
  7. acrumpton
    Apr 18, 2008
    28
    We had similar problems with GXP2000
    It turned out to be a firmware issue.
    Andy
  8. Halea
    Halea New Member
    Jan 5, 2008
    151
    Firmware upgrade on the Grandstream phones helped just a little bit, but freeing up the computer where I run 3CX from all the clutter (virus & spyware detector, useless programs running in the tray, or as service) helped alot. Now echo is down to a minimum and it's bearable. But in the meantime we figured out the fundamental reason behind "digital" echo. Most of the echo problems that VOIP phones are experiencing are not "analog" problems but digital echo cancellation shortcomings in the algorithms used.
    Halea
  9. wisecomputers
    wisecomputers New Member
    Apr 24, 2008
    126
    I wouold suggest if you are using a quility of service device to make sure you have it set to like a 1-10 in your device. Please be advised you also need to make sure you switch, and router can handle QOS.
  10. acrumpton
    Apr 18, 2008
    28
    I agree the firmware improved it to a usable level.
    Changing from Grandstream to Snom gave is a professional quality system.
    Andy
  11. Halea
    Halea New Member
    Jan 5, 2008
    151
    Andy,
    What makes the Snom phones any significantly better than the competition?
    What do you like so much about them?
    Just curious.
    Halea
  12. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    Halea,
    Snom has much more features, easier to configure, has much better standard comliance. Actually, we haven't found any deviations from standards which it supports. I'm working with Snom 360 with big pleasure. When something doesn't go right on it - it almost always means we have a bug.
  13. acrumpton
    Apr 18, 2008
    28
    I only have experience of Grandstream, Snom and a variety of softphones.
    I only know the call quality, configuration, firmware upgrading on the Snom was significantly improved compared to the Grandstream.
    That and I got a load half price!
    Sorry can't comment on other brands.
    For more info on Grandstream including firmware look at Grandstreamsucks.com
    regards
    Andy
