hello from new user
Discussion in '3CX Phone System - General' started by seanc, May 25, 2015.
  1. seanc
    May 25, 2015
    25
    hello, im new to 3CX :)
    a couple of questions if i may?
    if buy a 16 line system, do i need a 16 line IP phone for reception ? (actualy were only having 12 lines)
    Can you recommend anything for 12 lines, which needs PoE (power over ethernet)
    is there a half decent priced hand held phone that works with 3CX - prefer PoE but it doesnt matter.
    do u recommend a hardware firewall to run 3CX - i will have a couple of remote users using their cellphone with the app installed.
    we are considering sugarCRM integration, would installing sugarCRM+php+mysql work on the same server as 3cx is going to be installed.
    just checking, can i record EVERY call automaticaly ? i have the Professional version
  2. seanc
    May 25, 2015
    25
    also, is there any method to use an ordinary phone (a hands free phone in this case) with 3CX, any adapters/convertors?
  3. leejor
    10,362
    227
    I can answer a few questions. Reception does not have to have a 16 line set unless they want a key that corresponds to each extension, to see if that extension is busy (BLF key). Many installations will make use of DID trunks, where an outside caller can dial direct to the extension, or use of the Digital receptionist. If you choose to use a single public number and have all calls ring reception first and are then transferred to an extension, then a set capable of displaying the status of each set, might be useful. there are a number that make use of add-ons to increase the key capacity. The set can also be tied to a PC for more functionality.
    There are a number of sets that are supported by 3CX, and a lot that work just fine but aren't officially supported. Price points vary, and many users have their favourites.
    Standard analogue sets, corded and cordless, can be used on a VoIP system through an Analogue Telephone Adapter (ATA), there are a number available, they range from a single line unit, to ones with a dozen or more lines.
    As far as I'm aware, call recording can be set automatically, you must have the hardware to support this, especially on a larger system.
    Firewall choice many depend on your particular installation and usage, a number of hardware and software versions have been brought up in previous posts.
  4. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    2,962
    180
    I do not recommend installing anything on your PBX Server except the PBX server software.
