HELP 3CX to T1 PBX
Discussion in '3CX Phone System - General' started by jdoe, May 13, 2009.
  1. jdoe
    May 13, 2009
    We currently have a PBX and no plans to get rid of it. So I set up a 3CX server with some wireless phones but it's internal calling only. So, I spoke with one of the phone technicians about providing me with a T1 so I could get phone lines to my server. What I don't understand is what do I use for the T1 to interface to get my server outside lines? We are only going to use the server for our wireless phones.
  2. mhanson
    mhanson New Member
    Nov 6, 2008
    186
    Well, First off, you are going to need a T-1 to SIP Gateway to get your 3CX to communicate through the T1 to your old PBX. From there, It is going to depend.
    You are probably going to have to set an outbound route through the gateway into the PBX, which then would allow a 2nd stage of dialing to get out.
  3. jdoe
    May 13, 2009
    Can you recommend a model?
    Could I use an Adtran TSU 120 to connect to the server in place of a voip gateway?
  4. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,969
    270
    We dont support integration with other PBXs. However to connect 3CX to a T1 you need to use a supported gateway such as Patton 4960
