Help - 403 Forbidden
Discussion in '3CX Phone System - General' started by plindsay1, Sep 7, 2012.
  1. plindsay1
    Sep 7, 2012
    I recently upgrade my 3CX (free) phone system to Version 11.0.26364.600 in order to take advantage of the dial by name feature.
    Now, my one and only extension (a Grandstream 2100) will not make outgoing calls. It registers fine, and can receive calls. I'm stumped!
    My server activity log:
    07-09-2012 08:16:19.377 Leg L:20.1[Extn] is terminated: Cause: 200 BYE from PBX
    07-09-2012 08:16:19.315 [CM503020]: Call(C:20): Normal call termination. Call originator: Extn:110. Reason: Forbidden
    07-09-2012 08:16:19.315 [CM503016]: Call(C:20): Attempt to reach <sip:6132061056@192.168.2.110:5060> from Extn:110 has failed. Reason: Forbidden
    07-09-2012 08:16:19.268 Leg L:20.2[Line:10000>>16132061056] is terminated: Cause: 403 Forbidden/INVITE from 204.101.5.67:5065
    07-09-2012 08:16:19.268 [CM503003]: Call(C:20): Call to <sip:16132061056@sip.babytel.ca:5060> has failed; Cause: 403 Forbidden/INVITE from 204.101.5.67:5065
    07-09-2012 08:16:18.971 [CM503025]: Call(C:20): Calling T:Line:10000>>16132061056@[Dev:sip:16136866310@sip.babytel.ca:5060]
    07-09-2012 08:16:18.909 [CM503027]: Call(C:20): From: Extn:110 ("Paul Lindsay" <sip:110@192.168.2.110:5060>) to T:Line:10000>>16132061056@[Dev:sip:16136866310@sip.babytel.ca:5060]
    07-09-2012 08:16:18.909 [CM503004]: Call(C:20): Route 1: T:Line:10000>>16132061056@[Dev:sip:16136866310@sip.babytel.ca:5060]
    07-09-2012 08:16:18.893 [CM503001]: Call(C:20): Incoming call from Extn:110 to <sip:6132061056@192.168.2.110:5060>
    Any ideas???
  2. mixig
    mixig Active Member
    Dec 13, 2011
    523
    12
    you get forbidden from your provider, check format number for your outbound caller id and number format for number that you dialed (maybe the format is not t as it should be so provider returns forbidden)
  3. leejor
    10,754
    286
    The other examples I'm seeing, seem to indicate that they use port 5065, not 5060.
