HELP: Allow inbound calls in goip 4 with 3CX SP1
Discussion in '3CX Phone System - General' started by ltifoski, Aug 14, 2017.
  1. ltifoski
    Jul 29, 2017
    38
    Dear,
    I need help with my GOIP4 GSM GW. I'm not able to set up GOIP inbound calls to 3CX. Can someone help me?
    Thanks.
    Lucas Tifoski
  2. sip.bg
    sip.bg Active Member
    Nov 7, 2016
    704
    220
  3. ltifoski
    Jul 29, 2017
    38
    @sip.bg Thank you! Is working fine now!
    But, in my configuration, i used single server mode. It's working normaly.
    Thank you,
    Lucas Tifoski
