Help, AX100P card?
Discussion in '3CX Phone System - General' started by timurjaya, Mar 11, 2008.
  1. timurjaya
    Mar 11, 2008
    Hi all,
    I have a customer who use AX100P FXO PCI card for PSTN interconnection with 3CX Ph System. The problem is that 3CX extensions can't make a call through the local analog trunk on the AX100P port. Fyi, AX100P is a "X100P clone" card which designed for use with Asterisk/Trixbox system.
    Any solution to solve it, brothers? I would very appreciate for your responses!
    Warm regards,
    Timur Jaya
  2. alicic
    alicic New Member
    Oct 3, 2007
    119
    3CX does not support PCI Cards.
    Get Analog or Digital Gateway and solve your problem;-)
    regards,
  3. timurjaya
    Mar 11, 2008
    Oh really, I didn't know that before!? Thanks a lot anway!
    Regards,
    TJ
