HELP - Can't edit my VoIP Gateway settings
Discussion in '3CX Phone System - General' started by tobin, Jun 5, 2008.
  1. tobin
    Jun 5, 2008
    Please help.. Whenever I try to edit VOIP Gateway, I get the following error: "Time Between Registration Attempts Must Have Positive Integer Value"
    I have removed 3cx, rebooted and reinstalled 3cx yet I get the same error.
    I have checked the configuration file (3cxphonesystem.ini) and can't find any similar reference of "time between registration attempts".
    I am using 3cx release 4-4-08
  2. Andy Schmidt
    Andy Schmidt New Member
    Apr 3, 2008
    118
    It's not in the ini file - it's in the "gateways" table in the PostgreSQL database.
    Here's the setting they are referring to:
