Help: Configuration
Discussion in 'Windows' started by virgel07, Jan 5, 2012.
  1. virgel07
    Jan 5, 2012
    21
    Good Day!
    I seek for someone can help me to configure my Audicodes MP-104 to work with the 3cx Phone System. My 3cx Phone System are working smoothly in my lan using voip phone but i can't make it working in my pstn line to make receive and make a call. Your help are greatly appreciated. Thanks in advance.
    10,587
    253
  3. virgel07
    Jan 5, 2012
    21
    thanks for the reply. yeah my ip phone is already registered in my 3cx phone system and its working in our local voip. Now, i want to connect my pstn line to mp104 because i want an inbound and outbound call. I want to know how to do it in audiocodes mp104 fxo.
  4. virgel07
    Jan 5, 2012
    21
    1.) sip phone --->> voip gateway mp104 ---->> outside office pstn line
    PSTN Line
    2.) sip phone <<--- voip gateway mp104 <<---- outside office pstn line
    PSTN Line
  5. leejor
    10,587
    253
    Is this of any help? http://www.3cx.com/forums/audiocodes-mp-90.html
  6. virgel07
    Jan 5, 2012
    21
    sir, it helps, now after configuring my auidocodes mp118, the 3cx phone system registered the pstn extension created, i already created an outbound rules but i cannot make outbound call, im in the phillipines. local tel line is 7 digits. I tried to call also for the pstn line connected in my mp118 but it just ringing, i set an inbound rule to connect to my working extension line but nothing pick-up the call.
    ;** Ini File **
    ;Board: MP-118 FXS
    ;Serial Number: 480381
    ;Slot Number: 1
    ;Software Version: 4.60A.016.003
    ;Board IP Address: 10.1.10.10
    ;Board Subnet Mask: 255.255.0.0
    ;Board Default Gateway: 10.1.10.1
    ;Ram size: 32M Flash size: 8M
    ;Num DSPs: 2 Num DSP channels: 8
    ;Profile: NONE
    [SYSTEM Params]
    DNSPriServerIP = 10.1.10.1
    SyslogServerIP = 10.1.10.172
    EnableSyslog = 1
    [BSP Params]
    LocalOAMIPAddress = 192.168.0.180
    RoutingTableHopsCountColumn = 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0
    [ATM Params]
    [Analog Params]
    FXSLoopCharacteristicsFilename = 'MP11x10-1-fxs.dat'
    CallProgressTonesFilename = 'usa_tones_09.dat'
    [ControlProtocols Params]
    [MGCP Params]
    [MEGACO Params]
    EP_Num_0 = 0
    EP_Num_1 = 1
    EP_Num_2 = 0
    EP_Num_3 = 0
    EP_Num_4 = 0
    [SS7 Params]
    [Voice Engine Params]
    IdlePCMPattern = 85
    BrokenConnectionEventTimeout = 3
    [WEB Params]
    LogoWidth = '339'
    [SIP Params]
    ENABLECALLERID = 1
    MAXDIGITS = 11
    DISCONNECTONBUSYTONE = 0
    ISPROXYUSED = 1
    ISREGISTERNEEDED = 1
    PLAYRBTONE2TEL = 1
    ISWAITFORDIALTONE = 1
    ISTWOSTAGEDIAL = 0
    GWDEBUGLEVEL = 5
    PROXYNAME = '10.1.10.172'
    REGISTRARIP = '10.1.10.172'
    SIPGATEWAYNAME = 'audiocode.com'
    DISCONNECTONBROKENCONNECTION = 0
    REGISTRARNAME = '10.1.10.172'
    RINGSBEFORECALLERID = 0
    WAITFORDIALTIME = 400
    CODERNAME = g711Ulaw64k,20
    CODERNAME = g729,20
    CODERNAME = g726,20
    CODERNAME = g711Alaw64k,20
    CODERNAME = g7231,30
    CALLERDISPLAYINFO0 = Larry Potter 1,0
    CALLERDISPLAYINFO1 = Larry Potter 2,0
    CALLERDISPLAYINFO2 = Larry Potter 3,0
    CALLERDISPLAYINFO3 = Larry Potter 4,0
    PREFIX = *,10.1.10.172,*,0
    NUMBERMAPTEL2IP = *,0,$$,11,$$,$$,*,$$,*
    PSTNPREFIX = [200-201],1,*,*,0
    PSTNPREFIX = *,3,10001,*,0
    PSTNPREFIX = *,4,10002,*,0
    TARGETOFCHANNEL0 = 100,0
    TARGETOFCHANNEL1 = 100,0
    TARGETOFCHANNEL2 = 10001,1
    TARGETOFCHANNEL3 = 10002,1
    TRUNKGROUP_1 = 1-2,200,0
    TRUNKGROUP_3 = 3-3,10001,0
    TRUNKGROUP_4 = 4-4,10002,0
    PROXYIP = 10.1.10.172
    AUTHENTICATION_0 = 200,200
    AUTHENTICATION_1 = 201,201
    AUTHENTICATION_2 = 10001,10001
    AUTHENTICATION_3 = 10002,10002
    TRUNKGROUPSETTINGS = 1,0
    TRUNKGROUPSETTINGS = 2,1
    TRUNKGROUPSETTINGS = 3,1
    TRUNKGROUPSETTINGS = 4,1
    ENABLECALLERID_0 = 1
    ENABLECALLERID_1 = 1
    ENABLECALLERID_2 = 1
    ENABLECALLERID_3 = 1
    [VXML Params]
    [Audio Staging Params]
    [PSTN-SDH Params]
  7. virgel07
    Jan 5, 2012
    21
    I got this error when making outbound call..
    10:54:45.718 [CM503020]: Normal call termination. Reason: Not found
    10:54:45.718 [CM503016]: Call(3): Attempt to reach <sip:99902174@10.1.10.172:5060> failed. Reason: Not Found
    10:54:45.718 [CM503014]: Call(3): No known route to target: <sip:99902174@10.1.10.172:5060>
    10:54:45.718 [CM503010]: Making route(s) to <sip:99902174@10.1.10.172:5060>
    10:54:45.718 [CM505001]: Ext.400: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXPhone 6.0.20943.0] PBX contact: [sip:400@127.0.0.1:5060]
    10:54:45.703 [CM503001]: Call(3): Incoming call from Ext.400 to <sip:99902174@10.1.10.172:5060>
  8. virgel07
    Jan 5, 2012
    21
    sir, can u please guide me to setup from 3cx phone system to Audiocodes MP-118, pls. show me how the required setting will be put in 3cx Phone System and MP-118. Pls. include the guide for outbound call.
    PSTN Line: 9910553
    Thanks a lot.
  9. leejor
    10,587
    253
    This means that you have not created an outbound rule in 3CX to handle calls given the digits you are dialling. It doesn't know what to do with the call. Have a look at...
    http://www.3cx.com/docs/manual/
    As far as the incoming calls, I'm probably not going to be much help with that, as I'm not familiar with that gateway . Check the 3CX logs to see if there is any sign of an incoming call. If there is, then it is a 3CX configuration issue preventing the call from reaching an extension, post the log. If not, then it is a gateway setting, hopefully someone else can offer some suggestions. When a call comes in, (explaining in really basic terms), it is "forwarded" to the trunk number, in 3CX. There is usually a few seconds delay, in some areas (depending on the system used), to allow for receipt of caller ID information.
  10. virgel07
    Jan 5, 2012
    21
    Thanks for the fast reply!
    sir, is it possible that i will directly connect my pstn line to MP-104 FXO and make an outbound call?
    In our place supposed to be if i call locally the format is (062) 991 0551, we just need to dial 7 digits to reach (062) 991 0551.
    3cx Phone System Setup:
    Outbound Rule:
    Prefix:
    Call from from extension: 400
    Call to numbers with a length of: 7
    PSTN Line:
    Virtual Extension Number: 10000
    Authentication Id: 10000
    Authentication Password: 10000
    Port Idetification: 10000
    After creating this, it appeared Unregistered in 3CX Phone System, why?
    I got this message when i dial 991 0551:
    10:14:44.328 [CM503020]: Normal call termination. Reason: Not available
    10:14:44.328 [CM503016]: Call(36): Attempt to reach <sip:9902174@192.168.3.172:5060> failed. Reason: Not Registered
    10:14:44.312 [CM503016]: Call(36): Attempt to reach <sip:9902174@192.168.3.172:5060> failed. Reason: Not Registered
    10:14:44.312 [CM503017]: Call(36): Target is not registered: PSTNline:9902174 dialed on (AnyLine@SGC Local)
    10:14:44.312 [CM303003]: There are no available outbound lines on gateway SGC Local at this time.
    10:14:44.312 [CM503010]: Making route(s) to <sip:9902174@192.168.3.172:5060>
    10:14:44.312 [CM505001]: Ext.400: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXPhone 6.0.20943.0] PBX contact: [sip:400@127.0.0.1:5060]
    10:14:44.296 [CM503001]: Call(36): Incoming call from Ext.400 to <sip:9902174@192.168.3.172:5060>
    This is my Mp-104 Configuration.Ini
    ;** Ini File **
    ;Board: MP-104 FXO
    ;Serial Number: 575765
    ;Slot Number: 1
    ;Board IP Address: 192.168.3.173
    ;Board Subnet Mask: 255.255.255.0
    ;Board Default Gateway: 192.168.3.1
    ;Ram size: 16M Flash size: 4M
    ;Num DSPs: 1 Num DSP channels: 4
    ;Profile: NONE
    [SYSTEM Params]
    [BSP Params]
    [ATM Params]
    [Analog Params]
    CallProgressTonesFilename = 'usa_tones_11.dat'
    [MGCP Params]
    [MEGACO Params]
    [SS7 Params]
    IdlePCMPattern = 255
    RFC2833PayloadType = 101
    [WEB Params]
    LogoWidth = '339'
    [SIP Params]
    MAXDIGITS = 10
    ISTWOSTAGEDIAL = 0
    ISG72364USED = 0
    SIPGATEWAYNAME = 'audiocodes.com'
    ENABLEDIGITDELIVERY = 1
    ENABLEDIGITDELIVERY2IP = 1
    SIPTRANSPORTTYPE = 1
    CODERNAME = g7231r53,30
    PREFIX = *,192.168.3.1,*,0
    NUMBERMAPIP2TEL = *,0,$$,$$,$$,$$,*,$$,*
    PSTNPREFIX = 9910553,1,*,*,0
    TARGETOFCHANNEL0 = 9910553,1
    TRUNKGROUP_1 = 1-1,9910553,0
    AUTHENTICATION_0 = 10000,10000
    TRUNKGROUPSETTINGS = 2,2
    [VXML Params]
    [PSTN-SDH Params}
    Pls. correct me in this sir, Thanks a lot...
  11. leejor
    10,587
    253
    I'm not sure if the gateway or your 3CX is 192.169.3.172 or 173. You might want to check your IP settings.
  12. virgel07
    Jan 5, 2012
    21
    "I'm not sure if the gateway or your 3CX is 192.169.3.172 or 173. You might want to check your IP settings."
    192.169.3.172 = my pc ip
    192.169.3.173 = my mp104 gateway ip
  13. leejor
    10,587
    253
    So why is 3CX trying to reach 192.168.3.172:5060 (and failing) ?
    Do you have the correct IP datafilled against the trunk in 3CX?
  14. virgel07
    Jan 5, 2012
    21
    sir,
    i connect my telephone line to audiocodes mp104 FXO 4ports, is it correct? do i can make an outbound call after i configure my 3cx phone system w/ outbound rule?
  15. leejor
    10,587
    253
    If everything else is correct, then, yes, that's the way it should work.
  16. virgel07
    Jan 5, 2012
    21
    Sir,
    Pls. take a look, i try to make a local call from my extension: 136 to 9910551 and this is what i got;
    16:50:50.859 CallCtrl::eek:nLegConnected :[CM503007]: Call(141): Device joined: sip:10005@192.168.3.200:5060
    16:50:50.843 CallCtrl::eek:nLegConnected :[CM503007]: Call(141): Device joined: sip:136@192.168.3.136:5060
    16:50:50.828 Line::printEndpointInfo :[CM505002]: Gateway:[MP104FXO] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Audiocodes-Sip-Gateway-MP-104 FXO/v.4.60A.016.003] Transport: [sip:192.168.3.1:5060]
    16:50:48.234 CallCtrl::eek:nSelectRouteReq :[CM503004]: Call(141): Calling: PSTNline:10005@[Dev:sip:10005@192.168.3.200:5060, Dev:sip:10006@192.168.3.200:5060, Dev:sip:10007@192.168.3.200:5060, Dev:sip:10008@192.168.3.200:5060]
    16:50:48.125 CallCtrl::eek:nIncomingCall :[CM503001]: Call(141): Incoming call from Ext.136 to "9910551"[sip:9910551@192.168.3.1:5060]
    Their is no ring tone when i dialled 9910551, it automatically answered and i just heard a strange sound..tssshhhhhhh.
    Pls. take a look this is my MP-104 FXO .ini;
    ;** Ini File **
    ;Board: MP-104 FXO
    ;Slot Number: 1
    ;Board IP Address: 192.168.3.200
    ;Profile: NONE
    [SYSTEM Params]
    [BSP Params]
    [ATM Params]
    [Analog Params]
    FarEndDisconnectSilenceMethod = 0
    [MGCP Params]
    [MEGACO Params]
    [SS7 Params]
    VoiceVolume = 11
    InputGain = 11
    DTMFVolume = 0
    DTMFTransportType = 2
    [WEB Params]
    LogoWidth = '339'
    [SIP Params]
    MAXDIGITS = 11
    REGISTRATIONTIME = 60
    ISPROXYUSED = 1
    ISTWOSTAGEDIAL = 0
    ENABLECURRENTDISCONNECT = 1
    ENABLEREVERSALPOLARITY = 1
    CHANNELSELECTMODE = 1
    REGISTRARIP = '192.168.3.1'
    SIPGATEWAYNAME = 'MP104FXO'
    REGISTRARNAME = '192.168.3.1'
    CODERNAME_1 = g711Alaw64k,20
    CODERNAME_1 = g711Ulaw64k,20
    CALLERDISPLAYINFO0 = 10005,0
    CALLERDISPLAYINFO1 = 10006,0
    CALLERDISPLAYINFO2 = 10007,0
    CALLERDISPLAYINFO3 = 10008,0
    PREFIX = *,192.168.3.1,*,1
    PSTNPREFIX = *,1,10005,192.168.3.1,1
    TARGETOFCHANNEL0 = 10005,1
    TARGETOFCHANNEL1 = 10006,1
    TARGETOFCHANNEL2 = 10007,1
    TRUNKGROUP_1 = 1-1,10005,1
    TRUNKGROUP_1 = 2-2,10006,1
    TRUNKGROUP_1 = 3-3,10007,1
    PROXYIP = 192.168.3.1
    AUTHENTICATION_0 = 10005,10005
    AUTHENTICATION_1 = 10006,10006
    AUTHENTICATION_2 = 10007,10007
    TRUNKGROUPSETTINGS = 1,1
    TXDTMFOPTION = 4
    TELPROFILE_1 = Default Tel Profile,1,0,0,70,7,0,0,0,5,5,1,1,0,1
    [VXML Params]
    [PSTN-SDH Params]
  17. leejor
    10,587
    253
    You've changed the IP on the device and the call is going through correctly according to the 3CX logs.
    What happens beyond that, I'm not sure as I'm not familiar with the settings for that device. Did you try the phone line in other sockets on the device? If you don't have the phone line connected, does the call fail? If it fails, that would show the device is aware of an idle phone line being present. Can you listen on an extension, or call a local phone to see if the call is, in fact, going through but you just have no audio path?
    In many Gateways there is a one-stage/two-stage option, which I'd expect to give you dialtone if not set correctly.
    Some Gateways also have an internal dialplan, which, if not set-up correctly, can prevent some calls from going through.
    I'm really not sure if those issues apply here or not.
    If no one else, more familiar with your gateway, doesn't come up with any suggestions, you might do some searches for any configuration settings for the MP-104 (or similar models), when connecting with any type of PBX. There may just be one or two settings that require changing.
    You've got it to the point that 3CX is passing on the call, which is a big step.
  18. virgel07
    Jan 5, 2012
    21
    sir,
    it seems that i found difficulty in configuring the MP104 to work with the 3cx phone system, in this case i want to ask your suggestion what be may the good and right units that really work with the 3cx and it has an easy configuration
    Thank you!
  19. leejor
    10,587
    253
    "Easy Configuration"is very subjective, but if you want to go with a multi-line gateway that has been proven to work, then I'd recommend sticking to something that is supported by 3CX.
    https://www.3cx.com/voip-gateways
  20. virgel07
    Jan 5, 2012
    21
    Ok Sir, thank you very much for accomodating my querries. By the way, sir what version of 3cx that has a "Generate config file" button? My current 3cx version is 9 and i cannot see that button.
