Help configuring BrainTel
Discussion in '3CX Phone System - General' started by badtoad, Jan 22, 2008.
  1. badtoad
    I need help configuring BrainTel with 3CX. It successfully registers, but i can not make out going calls. It failed with 603 Declined.
    The provider is using Asterisk PBX at their end and here is a working configuration with asterisk.
    Outbound Caller ID: 210XXXX
    Trunk Name: Brain
    PEER Details:
    username=210XXXX
    type=peer
    secret=YYYY
    qualify=yes
    progressinband=yes
    port=8891
    nat=yes
    insecure=very
    host=chat.brain.net.pk
    fromuser=210XXXX
    fromdomain=chat.brain.net.pk:8891
    dtmfmode=rfc2833
    disallow=all
    context=from-trunk
    canreinvite=no
    authname=210XXXX
    auth=md5
    allow=g729
    Based upon above I made the following changes to Gateway / Provider Outbound Parameters section and defined custom values:
    To : Host Part = chat.brain.net.pk
    If I am missing anything?
    Here is the invite packet it is sending:
    SEND: INVITE sip:2100800@chat.brain.net.pk:8891 SIP/2.0
    Via: SIP/2.0/ ;branch=z9hG4bK-d87543-d56833136165922f-1--d87543-;rport
    Max-Forwards: 70
    Contact: <sip:210XXXX@24.16.98.7:55287>
    To: <sip:2100800@chat.brain.net.pk:8891>
    From: "100"<sip:210XXXX@chat.brain.net.pk:8891>;tag=7b535454
    Call-ID: NGY4OTcyMmZhZWI4MGExOWE0MDVlMTBkNmIwN2Y2MTY.
    CSeq: 1 INVITE
    Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO
    Content-Type: application/sdp
    User-Agent: 3CXPhoneSystem 5.0.3790.0
    Content-Length: 247
    v=0
    o=3cxPS 18069061632 391496335361 IN IP4 24.16.98.7
    s=3cxPS Audio call
    c=IN IP4 24.16.98.7
    t=0 0
    m=audio 9000 RTP/AVP 0 8 101
    c=IN IP4 24.16.98.7
    a=rtpmap:0 PCMU/8000
    a=rtpmap:8 PCMA/8000
    a=rtpmap:101 telephone-event/8000
    a=sendrecv
    I suspect that the issue is with To and From fileds where it is also including 8891 as the port, which might not be required.
    Any help is appreciated.
