HELP Configuring Cisco 232D
Discussion in '3CX Phone System - General' started by PIETROV, Sep 4, 2015.
  1. PIETROV
    Sep 4, 2015
    Hello. I need to use the Cisco 232D FXO port with my 3CX v12.5. I created a generic gateway in the 3CX and configured the SIP parameters in the Cisco and it's register but I can't call - out call go in timeout and in call don't get to the 3CX. How can I solve this problem?
    Thanks you to everyone.
    And sorry for my bad english but I'm Italian.
  2. PIETROV
    Sep 4, 2015
    Update.
    So, I managed to do ongoing call - the problem was that I was using the LAN port instead of the WAN. So I set up the LAN port as BRIDGE and now i can receive calls. But I still can't make, this is the log:
    04-set-2015 15:14:40.176 [CM503020]: Call(C:288): Normal call termination. Call originator: Extn:110. Reason: No answer
    04-set-2015 15:14:40.176 Leg L:288.2[Line:90003>>3**********] is terminated: Cause: 408 Request Timeout/INVITE from local
    04-set-2015 15:14:40.176 L:288.1[Extn] failed to reach Line:90003>>**********, reason No Answer
  3. leejor
    10,868
    304
    Did you have a read through this? Pay attention to the port number.
    http://www.3cx.com/forums/cisco-spa232d-41759.html
