HELP CONFIGURING DLINK DVG6008S AND 3CX !!!
Discussion in '3CX Phone System - General' started by manueldavid2k1, Sep 17, 2007.
  1. manueldavid2k1
    Jun 7, 2007
    I bought a DVG 6008S VOIP Gateway with 8 FXO Ports, 4 Lan ports and 1 Wan Ports, i'm trying to use 5 PSTN Lines with the gateway using 3cx, and the problems are:
    1st. The gateway can't register with 3cx
    2nd. The 3cx says:
    -Line:10000 doesn't match provided: 6646971 vs test1
    -Registration request from sip:6646971@192.168.0.202:5060 failed. Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    -REGISTER db4e97c2c663 cseq=REGISTER contact=6646971@192.168.0.203:5060 / 18 from(wire) failed authentication
    This is the first step to config the 3cx with the Gateway.
    Thanks !
