HELP - Connect SIP Provider to 3CX
Discussion in '3CX Phone System - General' started by dannyth, Nov 18, 2014.
  1. dannyth
    Nov 18, 2014
    I am trying to connect a SIP provider to my 3CX system but for the life of me I cant make it work or get a template that works
    The sip details required by the service are in the image, and it works perfectly configured as below in a Yealink phone.
    Anyone got any ideas or custom template that may work for me please?
    Dan
    [​IMG]
    10,852
    299
    Are you just using the Generic trunks setting in 3CX?
    What error message do you get in the 3CX Server log when registration is attempted?
    I'm not sure about the "register name". Normally the parameters are... User Name, Password, Server address/port, and sometimes a Proxy Server/port. Of course these do vary depending on the provider.
    Don't know if you came across this, or maybe it's your post.
    http://www.sys2u.com/xpert/viewtopic.php?f=10&t=14130
  3. dannyth
    Nov 18, 2014
    i went with Generic and also found a profile - the problem is it still gives an error
    19-Nov-2014 06:45:54.939 [CM504007]: Next attempt to register Lc:10000(@Thailand[<sip:+6621070460@catnextgen.com:5060>]) is scheduled in 5 minute
    19-Nov-2014 06:45:54.922 [CM504005]: Registration failed for: Lc:10000(@Thailand[<sip:+6621070460@catnextgen.com:5060>]); Cause: Cause: 504 Server Time-out - DNS Problem/REGISTER from 202.129.61.102:5060
    19-Nov-2014 06:45:53.329 [CM504003]: Sent registration request for Lc:10000(@Thailand[<sip:+6621070460@catnextgen.com:5060>])
  4. leejor
    10,852
    299
    Does catnextgen.com translate to IP 202.129.61.102 ? If so, then you should be able to try the IP as both the Server and Proxy server address.
    You might want to try leaving out the Proxy server altogether and see if it makes a difference. Worse case scenario, you ask your provider what they are seeing as incorrect when you attempt to register.
    Are you using a fixed IP at your end? Did you run the 3CX Firewall test?
  5. smart22
    Mar 13, 2013
    12
    I am also facing the same issue, same work in X-lite. Anything we can do in this case. Please update.
  6. leejor
    10,852
    299
    The same issue, with the same provider?
