help!! everything was working fine!!
Discussion in '3CX Phone System - General' started by aftermarket, Jul 7, 2009.
  1. aftermarket
    May 13, 2009
    84
    help!! everything was working fine then all of a sudden you cant call in nor call between extentions even though they register. i did just install the free call assistant will this have anything to do with the problem??????
    thanks in advance
  2. ec268
    Apr 18, 2009
    22
    Do you have PSTN lines intalled? Try to call outside and see the result.
  3. aftermarket
    May 13, 2009
    84
    hi no i dont i've fixed the problem. uninstalled call assistant and restarted and it went back to normal
