help for android
Discussion in 'Android' started by tracane, Jan 10, 2013.
  1. tracane
    Jan 10, 2013
    Hello, I purchased 3cx for my galaxy s3, I can't configure it with my provider "Messagenet"
    can you help, thanks
    11,282
    360
    Odd...since it isn't "for sale", it's a freely available download.
    Your provider would have given you some information...
    SIP server location and port
    Your Password
    Your ID (might be a (your) phone number)
    Perhaps a proxy server location
    Are you having difficulties determining where this information is to go? Did you put it in and the phone is not registering, both over WiFi and 3G?
    I'm assuming that you have read this... http://www.3cx.com/blog/3cxphone/android/configuring/
    You'll have to provide a bit more information.
