Help for setting up email notifications with Yahoo email
Discussion in '3CX Phone System - General' started by terrys, Dec 31, 2017.
  1. terrys
    Nov 20, 2014
    7
    I'm trying to set up notifications on a V10 system with Yahoo email and having no success!! Any help would be appreciated!!
    11,113
    329
    I assume that you are using the settings referred to here...
    https://help.yahoo.com/kb/SLN3217.html
    Came across a really old post from someone that supposedly got it working with 3CX, but they failed to follow up and post any setting that they used.
  3. terrys
    Nov 20, 2014
    7
    Thanks for your reply!! Yes, I also ran across that old post which really isn't much of a help!! I did try the setting as posted by Yahoo with no success. I'm hoping after the New Years headaches disappear later in the week someone will have the answer for me!!
