Help me figure out Gateways and POTs lines
Discussion in '3CX Phone System - General' started by TSlocum, Dec 22, 2014.
  1. TSlocum
    TSlocum New Member
    Oct 15, 2013
    225
    15
    After some research, it seems to me that a gateway (Patton Smartnode) is required if you have a POTs line. Is that correct? Secondly, is it required at all if you have a digital phone circuit, rather than a POTs line?
    11,073
    323
    If you have a voice service provider, other than VoIP, you will require a gateway of some sort, This includes, PSTN, PRI, and GSM trunks/lines.
  3. TSlocum
    TSlocum New Member
    Oct 15, 2013
    225
    15
    What if I have data only coming in to the location, with no voice service? 3CX and a Gateway would work with that?
  4. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,530
    298
    If you have no voice service - then no gateway is needed.
    Some voice services come in on Data lines... so talk with your current provider.
    Also ensure you are not under contract if you think you may be making a change to strictly VoIP.
    Many are listed within 3cx when you setup a new trunk.
    I save between 70-80% each month using VoIP instead of my PRI that I had previously from the phone company.
