Help me out please
Discussion in '3CX Phone System - General' started by batata, Nov 15, 2007.
  1. batata
    Oct 24, 2007
    I tried for the for hour to get my soft phone working but stiil at point zero.
    I also installed express talk this app works but the mic sound is not clear.
    My 3cx soft phone mic is not working I can hear clearly but my mic is not transmitting I have a soundmax sound card
    do I need to change the sound card can you recommend one, or should I buy a sip phone? I am really getting crazy Since I purchaged an account at inphonex.
    Please help me out
    Tank you
  2. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Hardphone's sound quality should be better than the softphone. The most people in used softphone should be x-lite/Eyebeam. X-lite is free version and Eyebeam is paid version. Soundmax sound card should be OK. Work with X-lite or other softphone are fine. Its depend on your MIC's quality. You can download x-lite at http://www.counterpath.com/xlitedownload.html for try out.
