SamuelKrawetz said:you will need a custom app to run a check on outbound calls from 3cx.
yea that really doesnt work for me I need to comply with the NDNC list which updates its database daily i believeSopock said:You can start from here
dnc-lists-cpa-compliance-43825.html
lifeline said:Reach out to the awesome folks at voiptools.com they can create this function for you.
They plan to use 3CX without any CRM?techhnyne said:it is a phone sales company that is required to have a do not call registry.
this is for a financial firm, and CRM is kind of useless for this install, outlook integration could help but anything more especially for $40+ per user would just be ridiculous considering that none of the CRMs pull stock quotes..Sopock said:They plan to use 3CX without any CRM?techhnyne said:it is a phone sales company that is required to have a do not call registry.
Verification
The problem with a “best guess” solution is there is no definitive database that maintains mobile phone number ownership.
Check your inbox!
We’ve sent you an email. Click on the button in the email body to verify your email address – (if you can not find it, check your spam folder).
Upon verification you will be directed to the 3CX setup wizard.
