HELP NEEDED
Discussion in '3CX Phone System - General' started by kirimis, Dec 21, 2007.
  1. kirimis
    Oct 16, 2007
    43
    can somebody tell me what is this message ? "MS004001] Call(52) Ext.131: Can't send RTP stream to 0.0.0.0:60000 destination unreachable"
  2. JamesC
    Dec 5, 2007
    20
    Not unless you give more detail, no.
  3. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,994
    304
    The ip is showing as 0.0.0.0
    That means the phone IP was not resolved and therefore you have network routing problems....
  4. Henk
    Henk Member
    Nov 13, 2007
    250
    Where is the call routed too?
    Like mentioned looks like a NAT issue.
    Make sure that you have a stun available and that your termination IP is known.
    H.
