help no incoming fax
Discussion in '3CX Phone System - General' started by MarcelvanKuilenburg, Nov 8, 2009.
  1. MarcelvanKuilenburg
    Nov 6, 2009
    29
    I did all the rules as mentioned in the 3cxmanual for the faxserver. Unfortunately I can not get any incoming fax. Fault on the extern fax is communication fault. the log is as follows
    • 15:30:39.874 [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 64.69.76.21:3478 over Transport 192.168.128.63:5060
      15:27:35.043 [CM504009]: Fax Service: changed contact to sip:888@192.168.128.63:5100;user=phone
      15:10:39.280 [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 64.69.76.21:3478 over Transport 192.168.128.63:5060
      14:59:50.537 [CM503008]: Call(44): Call is terminated
      14:59:04.568 [CM503007]: Call(44): Device joined: sip:888@192.168.128.63:5100;user=phone
      14:59:04.506 [CM503007]: Call(44): Device joined: sip:31852733629@sipnl.prionet.nl:5060
      14:59:04.490 [CM503002]: Call(44): Alerting sip:888@192.168.128.63:5100;user=phone
      14:59:04.459 [CM503025]: Call(44): Calling @[Dev:sip:888@192.168.128.63:5100;user=phone]
      14:59:04.412 [CM503004]: Call(44): Route 1: @[Dev:sip:888@192.168.128.63:5100;user=phone]
      14:59:04.412 [CM503010]: Making route(s) to <sip:888@192.168.128.63:5060;user=fax>
      14:59:04.412 [CM505003]: Provider:[Prionet] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Sippy] PBX contact: [sip:xxxx@94.208.144.255:5060]
      14:59:04.349 [CM503001]: Call(44): Incoming call from None@(Ln.10001@Prionet) to <sip:888@192.168.128.63:5060;user=fax>
      14:59:04.131 [CM503012]: Inbound out-of-office hours rule (VKA Fax) for 10001 forwards to Fax:888
  2. MarcelvanKuilenburg
    Nov 6, 2009
    29
    In the meantime I discovered the FAQ about the incoming voipfax. after exactly implementing this template, incoming voip works great.
    The only thing i have to discover is that the time on the corresponding email is UTC and not local (+1) Any ideas?
    next targer is the outgoing fax
    3cx is great again.
  3. callidus
    Jul 29, 2009
    17
    I have the same problem as you had..
    How did you resolve the problem?
    I just want to recive fax but i can't. I dont have a gateway or an analogfax.. I just use a provider..
    Regards,
    Irena
  4. danj
    Oct 26, 2007
    16
    The following FAQ should get you started!
    http: //wiki.3cx.com/documentation/fax-1/receiving-faxes-from-voip-providers/ - NO LONGER AVAILABLE
    Regards,
  5. callidus
    Jul 29, 2009
    17
    hmm..
    I have alredy set up those setings.. but i can't recive fax..
    Can fax be recived by any VoIP provider or must the service "fax to mail" by the provider be turned on?
  6. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    You SIP provider MUST support t.38 fax or you will not get faxing to work properly. Since most T.38 implementations today are poor hacks to try to get it to work, your success rate will probably either be pretty good or virtually zero.
